Duratrax Evader ST Nitro
I recently purchased this gas r/c truck and have run less than 3/4 of a gallon of fuel through it.
It started getting hard to start and now will not run at all. I have changed the glow plug, changed the battery in the glow plug starter, tried new fuel and also tried to change to the carb settings to no evail. People have told me that I may have run it too lean - I don't agree as I adjusted per the manual that came with the vehicle.
I have pulled the cylinder and piston out of the engine - how can I tell if they are warn out? And is the DTX .18 a quality engine? Is it worth rebuilding it or should I replace it with an O.S. Max CVR .18 engine?
Any ideas that you can give me would be great - this is getting expensive and I am not sure I should have bought this.
does the engine have good compression? when u turn the flywheel, does it have resistance? is the air filter clogged? any leaks in the lines? do u prime it before starting?
is the oneway bearing in the pullstart locked up????
btw,the engine you have is made by O.S. although its of lower quality
Does the engine pop at least when you try and start it? If so adjust the idle screw clockwise.
Make sure you prime the engine.
Sean
Sean
Hi - and thank you for your responses. I have tried everything that you are talking about and still have no luck in starting the car. How can I tell if the engine is wore out or if has been overheated? I am trying to weigh replacing the engine vs. rebuilding it.
Thank you for your help - it is really appreciated!
I don't know what to say.
If the engine is primed, the idle screw is set right, the glow plug is new, the fuels new, the glow ignitor's batteries are new it must start.
To tell if the engine is worn (i doubt it) spin the flywheel with your finger and see if there is a fair amount of pinch or compression in the engine as the flywheel turns over.
Try heating up the engine before starting it and definetely buy a new glow plug if you haven't already as glowplugs are usually stuffed after the break in period.
Sean
Sean
Check your clutch. The spring probably snapped causing it to lock up like mine did.
