Transmission problem 2wd stadium truck please help
Sons truck just quit pulling this afternoon. Took it apart no signs of any problem. Clutch is working fine all the gears in side case are fine spider gears dont have any teeth gone so I dont know what to is wrong with it. It trys to pull its self but one finger will hold it back help please.
Sounds like the hexes/pins in the wheels may be stripped!
nope
No I dont think so the shafts dont turn ether .
Every thing is turning clutch gears pinion and spur gear just not the drive axles
clutch shaft is turning to
What brand of truck is it? I think some use a pin on the top gear shaft behind the spur...like Traxxas....Seems to me I have broke one on my Slash before.
Electrix, cheaper stuff but it all cost money ya now. We have been having alot of fun racing in the yard I bought 2 of them. My was new I bought my sons first at a hobby shop used
got it fixed it was the clutch shaft gear it was slipping it will hold for a little while guess its time to up grade trans parts, stay with plastic or go with steel if so do I have to change out the gear case.
