soe body can explain me that weld on tekin rx8
#17
yes, as you said, red and black connected and welded, removed from the red cable of the battery and no power, other strange thing is if I touch the red battery cable (the positive one) with the red of the switch alone no power on the esc, if i do the same with the black no power too, they need to be connected, I touch the positive of the battery and power is on, very very strange that problem.
#18
On another note... I like having the switch, it has not been a problem for me except for the issue of finding a place to put the switch that works well and is only 2 inches from the ESC. I wish it was standard practice to build it into the case of the ESC, and to make the anti-switch crowd happy maybe put a bypass jumper in the case so it is always on when the battery is attached. < HINT HINT to all you manufactures out there >
#19
Ya, I think someone fried the internal board relay and they decided to bypass it with a hardwire.
Its ingenuitive, but dangerous.
