TLR 22-4 THREAD
#3558
I will play around with my shocks tomorrow but I have to say I like about a 50/50 rebound. Standard shock build is probably 25/75. It makes the kit feel more in the dirt IMO. (neutral in the roll of the ride height). They seem to resist airing up better. The kit will go over bumps and light risers with more stability. If you note the kit on the track the tires really never look like there bouncing or tapping on small ruts/bumps. Aside from wash boards that is. And I like the feel of how it makes the kit feel low and tight in the air off jumps. That's not the weight of the kit making it feel like that alone. In my on road days we could achieve 25/75 50/50 etc. by the amount of foam we would put in the cap between the bladder. 12mm shocks are prone to this. Not sure why but bladders could be an option? I have been setting the ride height with the lid on ready to race.
I will add that these seals are very good. The fine tips on the inner part of the ring allow for a very smooth stroke. As they wear the ring swells and will over all stay smooth longer then the average ring. After they swell that vacuum will dissipate some. And can be a good gauge on when to replace them.
#3559
I never paid any attention to this on my scte. Just checked rebound
I did notice the more you bleed, the more vacuum up action you get. No youtube video addresses this. Just rebound.
#3560
They were having the same issue with the Ae BB's So I did this vid. It worked for the AE shocks. There's a lot of ways to bleed shocks but this worked with the AE BB.
https://www.youtube.com/watch?v=GitM0-hWFgc
#3561
Here's a great vid and we are pretty much on the same page with pistons with our TLR shocks.. It demonstrates the difference in the shock and the opposite effect. Most likely why we experience the suction from the bottom due to it is actually working just the opposite. raz is pretty hip on demo's. I highly recommend you watch all of his RC vids....
https://www.youtube.com/watch?v=aU_0wvD2m7E
#3562
I like the damper to have about the same suck-back at beginning and end stroke.
#3563
I found that the nature of the shock is to suck back in so I let it. And it really is a lot smoother off power in and out of the turns. Add that to the right oil and spring combo you can corner like a bandit. Its a natural when it comes to the pack, so the roll is better if you leave the suction in there when you bleed them.
#3564
Its the nature of all bleeder cap shocks to pull the shaft back. They have no rebound normally, and you do your best to limit the recoil of the shaft.
I will test this out tomorrow to see which way but I believe if you put the bleeder screw in quickly after pushing the shaft all the way in you get less (or more) shaft recoil. I'm not sure if its less or more but i'll try tomorrow. The alternative to as quickly as possibly putting it in would be to wait maybe 3-5 seconds before putting it in.
Also as fair warning I have never read the advice above anywhere, nor heard it anywhere. It is my own personal experience with the SCTE shocks.
Bleeding the screws twice causes the shafts to recoil even more for me.... which would support my theory that by putting the screws in immediately (like the very instant) you finish pushing the shaft up will limit the recoil effect.
#3567
UN4RACING, uclabruins89 and bergie33
I do have binding in the front. My local hs told me "That's because its new, unused. Binding will stop once on the track."
I took out the grub screws. Back is super loose.
#3569
Apparently you have to power cycle the rx to have the changed esc functions. That's what I read in another thread anyway.
