Tekin Gen2 RS Spec Edition
Uploaded with ImageShack.us
ROAR Spec Mode only, no Timing features
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, Custom)
ROAR Race Spec "Blinky" Mode
Save, Load and Share custom ESC setup files*
Save, Load and Share Data Log files*
Extensive Tuning via Tekin HotWire PC Interface
*Requires HotWire Sold Separately
Controls: Forward/Brake/Reverse
Input Voltage: 4-9 Cells, 2S-3S Lipo
BEC: 6.0v 3.7amps
Motor Limit Brushless Mode: 13.5 Turn, 540 2-pole (36mm)
Motor Limit Brushed Fwd Only Mode: 20 Turn Silver Can
Motor Limit Brushed Fwd/Rev Mode: 20 Turn Silver Can
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.0 x 1.3 x .51in (25.4 x 33 x 12.9mm)
Weight: .80oz / 22.5g
http://www.teamtekin.com/rs_spec.html
TT1155 - RS GEN2 SPEC ESC
Street Price - $135
TT2429 - RSG2 + GEN2 21.5r
TT2430 - RSG2 + GEN2 21.5
TT2431 - RSG2 + GEN2 17.5r
TT2432 - RSG2 + GEN2 17.5
TT2433 - RSG2 + GEN2 13.5r
TT2434 - RSG2 + GEN2 13.5
Street Price - $185
I dont really care much for boost. It has its place on on high bite and onroad, so I like this idea. My only issues with this spec esc is the 13.5 limit. Orion and a few others make stock spec esc's but they often go down to 9.5 turns. So you can run a mild mod if you like.
I always run boost, it lets me run a 9.5 in 2Mod so the bottom end is easier to hang onto but it still winds out on the straight like a full mod motor.
The time it records depends on how many parameters you have set to record and the sample rate. Once the memory is full, it stops recording any further. It records on a graph and yes it shows time.
It's better that the previous generation at 3a. I ditched savox servos, as I had nothing but trouble with them and never looked back.
This will be perfect for my TLR 22 2.0 build! No use for a 7.4 BEC and I run Futaba so brownout isn't an issue for me even with the Castle ESCs I have in my bashers.
