Old 09-22-2013, 07:02 AM   #1
Questions?? losi xxx sct front and rear wheel nut help!!
I was wondering is there a way to make the rear wheel nuts match the front ones?
Racin Dirt is offline   Reply With Quote
Old 09-22-2013, 11:31 AM   #2
AndrewTom's Avatar
Pro Line inboard hub conversion:
http://prolineracing.com/performance...t-inboard-hub/
seriously, google is your friend.
Andrew T. Larson
AndrewTom is offline   Reply With Quote
Old 09-22-2013, 11:43 AM   #3
Thats the front hubs....Im looking to change the wheel nuts in the rear to match the ones on the front becsuse right now the rear nuts are bigger. I wasnt sure if there was a different rear axle i could run that uses a smaller nut.
Old 09-22-2013, 11:51 AM   #4
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Right...no there's no mod to make the rear smaller...the pro line kit makes the front bigger (and allows you to run hexes all around) thus giving you the same nuts front and rear.
www.smc-racing.net for all of your Lipo needs
RC10B5, Caster S10B Pro, 22T
Grasschopper is offline   Reply With Quote
