Is there a technique to correct a swelled/puffed lipo? >
Old 09-21-2013, 05:48 PM
  #16
Tech Legend
Wild Cherry's Avatar
Jkas just yesterday...
took a swelled up shorty and charged as I suggested and we saw great results.
Way
Better then the stabing method and costs nothing to try.
Wild Cherry is offline
Old 09-21-2013, 06:07 PM
  #17
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
puff puff pass...............in more ways than one.
racer1812 is offline
Old 09-21-2013, 06:29 PM
  #18
R/C Tech Elite Member
jkas10's Avatar
Trader Rating: 123 (100%+)
Way
Thanks - giving it a try now. Definitely will try other options before cracking a case...
jkas10 is offline
Old 09-21-2013, 07:07 PM
  #19
Odin544's Avatar
Trader Rating: 93 (100%+)
Ever been near a lipo fire? Hopefully if you ever have been you will realize how stupid trying to save a puffed lipo can be. Why risk it? Why risk your equipment and others equipment around you? All over < $100. No thanks.
Odin544 is offline
Old 09-21-2013, 07:45 PM
  #20
Davidka's Avatar
Trader Rating: 86 (100%+)
Originally Posted by jkas10
So, the plastic "bag" the cell is wrapped in is sealed, and the puff is from an excess discharge of gas in the "bag"? Is that correct? Can a guy - carefully - relieve the excess gas with a pin hole or something and release the built up pressure?
Yes. As Racer 1812 said, if you can feel a gap between the case and cells the you're probably fine (puffed cells feel very firm). If you believe the cells have puffed, just trash the battery. LiPo fires are very dangerous, both because they're hot, hard to extinguish fires and because the smoke that comes off of them is pretty poisonous.
Batteries are too cheap these days to take the risk.
Davidka is offline
Old 09-23-2013, 03:32 PM
  #21
the incubus's Avatar
Trader Rating: 17 (100%+)
Just a tip, if you ever encounter a LiPo fire, the best way to turn it off is to remove the body and pack in dirt all over to suffocate the oxygen being fed to the accelerants. I had a foam fly off my 4.2 and the battery slid back and made contact with my ESC Shelf (thankfully I had just moved my RS Pro to the left side) and shorted out until the heat built up enough to ignite the resin in the Carbon Fiber so it was a dual fire. LiPo & CF fire and I pulled the body off immediately and packed in clay and it extinguished instantly. Also the clay is cool under the first layer so it also dissipates heat right away.
the incubus is offline
Old 09-23-2013, 05:58 PM
  #22
Stevevanb's Avatar
I have a set of HVR saddles that started to puff. I'm a little bummed to say the least. I think I may have pushed em a little to hard in my Durango short course truck.....
Stevevanb is offline
