Jammin rear end too loose
Anyone else find the Jammin to be loose in the rear? If so how do you get it planted? I'm running 1K in the rear diff with 5K in the center and 3K up front. 40wt. oil all around with blue springs and Komodo dragons. It has good steering but wants to break loose in the turns and on the throttle.
ya change the diff fluids to 5-7-2 and you will notice a difference. If anything mine pushes a little in the turns, but I can adjust that by putting a thicker sway bar in the rear.
