Help, rx8 with no rx wire
#16
#18
Here is a pic:
You can follow the (dusty) wires and see from left to right it is white, red, black. Also, the switch is the two spots next to the receiver wires.
I shortened the receiver wire on my RX8. With decent soldering skills and a fine tipped iron, it is not difficult. just make sure there is no solder across the different points.
#19
Hard to tell by the pic are u saying the first three on the left are the receiver. Or the last three? And the switch wires which order are they?
#21
Yeah that's clear thanks, now to debate if I can solder good enough to pull that off lol
#23
Yeah the trick is not too much heat, but just enough along with a small tip.
Again I'd be VERY Careful powering it up for the first time. Sketchy that they're removed in the first place.
#24
Yeah I'm a little worried about doing it, and why it's gone maybe sending to tekin is best.
#25
Thanks for the help everyone
