Old 06-18-2005, 11:44 AM   #16
Nick111's Avatar
Send a message via AIM to Nick111
That's what I used at the season opener. Loose as can be. I mean I was running an LIR setup, but it shouldn't have been as loose as it was.
Nick111 is offline   Reply With Quote
Old 06-18-2005, 03:05 PM   #17
Team Dorkmissle's Avatar
the trick with glueing 4wd fronts is to take your time. i have done mine for long time now. i start out by cutting the rear tire down middle of the tread. figure out how many pins you need to cut out of each side. make sure you do the same on both sides. using straight body trimmers cut each side evenly. now comes the fun part. what probably works best for glueing them back together is take a penny or something simular and apply some ca glue to it. take an old x-acto kinfe and dip it on the glue. apply the glue to a small area on one tire. now hold the two pieces of tire together and let dry. then continue around the tire doin just a small area at a time. this process takes a while to make a pair but it is how you have to do it if you have to run a certain set of tires. sorry i dont have any pics of how to make them but if any more questions let me know.
Team Dorkmissle is offline   Reply With Quote
Rubber Tire Question CREWMAN Electric On-Road 10 06-04-2008 09:52 AM
MaxMod Tire Truer (large AC version w/adjustment for cutting camber into the tire) Danny-The-Dude R/C Items: For Sale/Trade 3 02-26-2007 02:10 PM
Vinyl cutting. Question... bvoltz Painting, Designs, Graphics and Photography 3 05-06-2006 06:35 AM
Rubber tire wear Question Ridge_Racer Rookie Zone 4 12-15-2005 11:45 AM
1/12 Tires and tire cutting ?? FUK_WRX Australian Racing 5 08-05-2003 03:40 PM
SEO by vBSEO 3.5.0
