TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#9797
#9798
They should not hit at full throw, unless you are running 4mm under ball stud. If you are running 4mm then just trim the ball cups a little with a exacto knife.
#9800
Finally got my 2.0 out to race, great improvement from my 22, hadnt raced in over a year and made a-main in both my classes which both had multiple mains, 17.5 blinky(2nd out of 17) and 13.5 running car still in 17.5 blinky(4th out of 28). had to lighten rear to gray springs and turn out eyelets to 2 turns for more traction under braking, my question is the car felt a bit "numb" in the tight 180's and I'm looking for the best way to make it more aggressive thru the tight ones with out loosing that over all stable feel that car has, I want to be able to power thru them instead of having to use the brakes to get rear to swing thru, I'm rear motor with full size stick pack, any suggestions would be great, thanks
#9801
Full size stick pack = numb at least in my book.
I run shorty pack.....only 3,300mah....very light. Works GREAT for me, a very nimble car....like a 1/12 scale car for off road.
M4 suburbs on the front are the key item for my front end to get best steering.
#9803
Avid red is 3.33, Avid Purple 3.62. So I'd even try purple. I ran purple for a day and liked it, but threw the KYO gold on when it came in the mail. Seemed about the same.
#9805
Yeah Silver LF not really close. KYO gold is supposed to be 3.87 (measured at 3.34 according to some charts?)
#9806
