TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#4906
Been running without it since Dustin ran it at JCONCEPTS race in MA. No issues. Been running indoor and outdoor on a big track.
#4908
The best thing to happen to 22 based mid motor vehicles would be a more compact(shorter) transmission. The motor is too far from the axle centerline. Having both a RM 22 and MM22 along with a MM 22sct, I couldnt belive the different feel from a Centro or the Tamiya mm I drove. Compact trans makes a better balanced car and transmits more force to the rear wheels for forward bite.
Maybe mbtoolmaker35 can do this? Obviously alloy not brass.
#4909
#4911
When you removed your waterfall, did you happen to cut off the part of the waterfall that goes between the transmission and motor plate and put a screw back in there? If not, you are allowing too much flex in the motor plate and that twisting is what is causing your issue. You HAVE to put a screw in that open hole when you remove the waterfall.
#4912
do I need a hotwire or be ok with out one?
#4914
#4916
#4918
