Like Tree31Likes
Old 08-14-2017, 12:43 AM   #11431
czrlaker's Avatar
Trader Rating: 23 (100%+)
Thanks for the input.
czrlaker is offline   Reply With Quote
Old 08-15-2017, 09:52 PM   #11432
mustangkillaz's Avatar
Any if you guys install a turnbuckle for steering in place of long set screw? If so, what length or type did you use?
mustangkillaz is offline   Reply With Quote
Old 08-16-2017, 02:05 AM   #11433
Default Non-HB Wheels
I don't know if this has been answered yet, but what wheels do you all suggest? HB wheels for this car are not always available at my LHS and I need a contingency. I have always liked DE Racing wheels but they do not make anything specifically for the D413. Will another buggy's wheels fit and if so, which one's?
- Tekno SCT410.3
- HB D413
Tibbar110 is offline   Reply With Quote
Old 08-16-2017, 03:02 AM   #11434
DE wheels are on my d216. D413 rear wheels are the same . The DE wheels I've got have a AR part number in the rear. Iirc, it's for associated b5 or 6. The fronts are off a TLR 22-2 and have a smaller hex and won't work on a d413.
The front losi 22-4 wheel should fit from what I remember.
Call DE, the guy is super helpful and I'm sure he'll get you the right part numbers. I had a very good experience with them and if not buying factory white wheels, they have my business.
Old 08-16-2017, 05:19 AM   #11435
czrlaker's Avatar
Alright so I get to run it for the first time today. I have currently installed the Exotek spring perch all around, I went with the 15°casters for running on carpet, and the steering rack, spur gear not installed, I'll wait for the stock to go out if ever.
Now to my question, I really like the thought of the motor split plates for easy diff access (love Team Durango easy access designs). But it seems that easier access is already available via the exotek chassis. If I get the chassis would it make the motor plate parts irrelevant? Thoughts? Pros Cons? Or get both?
Old 08-16-2017, 05:36 AM   #11436
MD
MD's Avatar
Trader Rating: 116 (100%+)
22-4 front wheels fit.
MD is offline   Reply With Quote
Old 08-16-2017, 06:23 AM   #11437
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
For the wheel question I run B6 offset wheels rear, and 22-4 12mm hex wheels front and they work fine.
I have both the chassis and mounts and personally I would say get split diffs if you plan to run a chassis protector. that is one less thing you have to try to remove to get to the diffs. I also find it easier to line up the center dog bones without trying to screw in the diff from the bottom.
So got another race night in the books, a guy who mainly runs FPV quads quite well ran with a D413 and I believe a 13.5 motor as well and ended up winning it all. My setup felt a bit tippy as the tires I used were took grippy at times and others was loose in the rear. Rear just didn't transition quite like I wanted smoothly. As we were moving pretty fast with the heats I didn't have time to switch and just went with it. Took 4th.
All in all though the vehicle still performs. I did notice a weird donkey kick off a certain jump I had not seen before that i may look into addressing.
I am running VRP 3 x 1.3 pistons all around, I am thinking though of trying the 2 x 1.6 and 2 x 1.7 setup for a bit better grip due to how bumpy it is.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 08-16-2017, 09:05 AM   #11438
Is the offset correct?
Old 08-16-2017, 09:18 AM   #11439
MD
MD's Avatar
I think so. I had a set of tires and wheels I took from my 22-4 and ran them in a parking lot race on my D413 and they seemed fine.
Old 08-16-2017, 09:21 AM   #11440
czrlaker's Avatar
Thanks, What's the verdict on Exotek chassis? I know its not necessary but is it a wise investment?
Old 08-16-2017, 09:28 AM   #11441
Tech Legend
Cain's Avatar
I am liking it just from the fact those darn top bracing plates aren't used
It feels good around the track, no complaints and that is from both loose rough dirt and carpet.
Old 08-16-2017, 09:36 AM   #11442
czrlaker's Avatar
That settles it. Thanks.
Old 08-16-2017, 11:46 AM   #11443
tc5 man's Avatar
I would stick with the wheels that have a deep insert in the middle so the axle doesn't stick out so far . Not to mention the ones where there isn't a deep insert in the middle of the wheel the offset is more narrow im pretty sure i noticed a handleing difference . Now if you use Evo Front wheels or Rear you don't have a choice .
22-4 Front wheels are perfect and the B5/b6 Rear wheels .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 08-16-2017, 03:56 PM   #11444
So would these fit?:
https://www.amainhobbies.com/de-racing-12mm-hex-speedline-2.2-4wd-front-buggy-wheels-2-224-black-der-sb-l4b/p296197
https://www.amainhobbies.com/de-racing-12mm-hex-borrego-2.2-1-10-buggy-rear-wheels-2-b6-rb6-black-der-bb-lrb/p215067
Old 08-22-2017, 08:54 AM   #11445
Tech Legend
Cain's Avatar
so got some more runs in, trying a different motor and wow she is a beast for 13.5 .
I need to change my setup for sure, I am liking my daughters one i put on hers so will probably start with that. The biggest change will be the pistons, using VRP 3 x 1.3s but she just feels a hair too inconsistent for our conditions here. Probably just sell em.
She is running 10-200-7 versus my 10-200-5, a longer wheel base setup, and different shock pistons (1.6 2 hole front, 1.7 2 hole rear) and her car felt really good. Chassis is still schelle graphite but very curious to try out the changes on mine.
Anyway, my daughter managed to snap the ball stud going into the Exotek steering rack. It looks like the stud could be threaded out from the other end, any tips on doing that? plan to heat it up to break any threadlock bonds and then go from there.
