Like Tree28Likes
Old 01-25-2017, 01:04 PM   #10966
snwchris's Avatar
Originally Posted by 2004hdfxsti View Post
anyone else having a problem with wearing through front skid plates really quick? I have tried the T Bone racing ones and am not a fan. They seem to bend and pull through the screws. Just seems like I go through a skid plate every few months (racing weekly)
I raced mine very week, indoors and outdoors for 1.5 years and never wore thru one.
Either have a material issue, or some really low ride height and chassis slap
snwchris is offline   Reply With Quote
Old 01-25-2017, 01:09 PM   #10967
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Cain View Post
thanks!
so did a search on servo horns, are these the right ones:
https://www.amainhobbies.com/losi-al...sa99032/p13553
https://www.amainhobbies.com/hb-raci...s67169/p148908
If not which ones?
Also how hard is it to do the mod for the exotek chassis or is it to just better drop the $25 dollars on the parts?
What ever horn you end up with, make sure it's clamping. Will last you 10 times longer than a press on type in regards to slop...
Hot Bodies D413 1/10 4WD Buggy-dsc_0066__34030.1477950236.1280.1280.jpg
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-25-2017, 01:11 PM   #10968
MikeR's Avatar
Originally Posted by Cameron Kellogg View Post
David's set up from the last big carpet race. Pictures show he was using a Exotek chassis but he does not "officially" say so.
Thanks for posting it.) Confirms what we know about the Exotek chassis
Old 01-25-2017, 02:26 PM   #10969
STLNLST's Avatar
Trader Rating: 19 (100%+)
MikeR- Did you ever get my email?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2017, 02:36 PM   #10970
MikeR's Avatar
Hi, replied
Old 01-25-2017, 06:11 PM   #10971
EbbTide's Avatar
Trader Rating: 32 (100%+)
I have a bit of an odd issue some of you might be able to help with.
Do you guys do anything special to get double sided tape off clean with the carbon fiber chassis? This stuff is not coming off clean the way I usually do it by peeling it off.
EbbTide is online now   Reply With Quote
Old 01-25-2017, 06:44 PM   #10972
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I use goo gone at times and it helps to get it off clean. just got to kind of soak it a bit.
Alright so I got 2 of these on the way. one will come with the Schelle graphite chassis that I think is new or like new and a ton of NIB parts.
Anyway, what are peoples thoughts on these chassis versus the exotek for 13.5 spec racing?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-25-2017, 06:51 PM   #10973
EbbTide's Avatar
Thanks Cain I'll give goo-gone a shot
Old 01-25-2017, 06:58 PM   #10974
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I attended an event on a hard packed track with some poorly made big jumps. Completely went through a front plate in 6 runs. A rear in 8. My home track I can run for months without worry. So it is possible on the right surface. Kinda like it can be replaced easy.
Cameron Kellogg is offline   Reply With Quote
Old 01-25-2017, 07:09 PM   #10975
Most spec racing is about running less weight. So depending on your racing handling pays off more than light weight. Then the Exotek could be faster. Mod normally power is plenty so the heaver chassis adds stability and drivability.
Old 01-26-2017, 05:21 AM   #10976
I do get a bit of slap, but they seem to go quick. wearable part i guess....
2004hdfxsti is offline   Reply With Quote
Old 01-26-2017, 07:58 AM   #10977
Tech Legend
Cain's Avatar
cool. I may still do the dual exotek chassis setups and sell the Schelle one depending on how far I want to run with the D413s.
How hard is it to modify the plates that are needed for the exotek conversions?
So what right now is considered a great base outdoor loose track setup to go with?
Lastly, I noticed some drivers here had issues with the spring cups. I see various posts about it on the thread, but it seems like its either exotek or you have the stockers on wrong. Is that right?
Old 01-28-2017, 03:02 AM   #10978
EbbTide's Avatar
I'm actually considering the exotek chassis myself. And the modifications don't seem all that difficult to achieve with just a cutoff wheel and some steady hands. However I think I'm going to just buy the extra bits for a cleaner look plus my cuts tend to be a little crooked lol.
But regardless I think I'll at least try the CF chassis before I splurge on the exotek kit. Even though it does look sweet and makes maintenance less of a headache
Old 01-28-2017, 06:12 AM   #10979
Tech Legend
Cain's Avatar
yeah I may have a line here on another D413 with exotek chassis, so will see what happens. If its pretty straight forward modifying the various plates I don't mind not having a perfect cut versus spending $25 for that.
Old 01-28-2017, 11:17 PM   #10980
nitro2be's Avatar
Yes on spring cups.
nitro2be is offline   Reply With Quote
