Like Tree31Likes
Old 01-09-2017, 07:33 PM   #10921
EbbTide's Avatar
Trader Rating: 34 (100%+)
Originally Posted by STLNLST View Post
M3x20 steel screws. These get bent in the front a lot.
Those longer m3 screws do like to go quick, thanks for the heads up. Luckily I recently bought a small batch of those for my 1/8 buggy
EbbTide is offline   Reply With Quote
Old 01-13-2017, 01:50 PM   #10922
EbbTide's Avatar
Might be a dumb question but is anyone running 2wd front wheels and tires on this buggy?
I've seen some guys in the for sale threads with really skinny fronts and wasn't sure if they were 2wd fronts or not.
Old 01-13-2017, 01:54 PM   #10923
We race on a high bite carpet track. The normal 4wd front wheels is too much, so we use 2wd fronts. So for 2wd buggys normally we trim the inside lip to mount the tires which give it a very skinny look, but for 4wd applications we don't. Hope this helps.
achtung1970 is offline   Reply With Quote
Old 01-13-2017, 01:57 PM   #10924
EbbTide's Avatar
Thank you for that I may just pick up a set of 2wd fronts to try out in that case. It's nice to know there are more wheel options than strictly running 4wd fronts.
Old 01-14-2017, 02:50 PM   #10925
How do I get more on power steering ? I'm running 5k 100k 2k always spins out exiting turns if I'm on power
vanpaassen is offline   Reply With Quote
Old 01-14-2017, 03:03 PM   #10926
EbbTide's Avatar
You could try softer Springs and lighter weight oil in the rear to help keep the rear end planted. Also if you've got a lot of negative camber in the rear, I'd try to limit it.
Old 01-14-2017, 10:30 PM   #10927
nitro2be's Avatar
10k or even 15k front. I've ran 5k from and was terrible.
nitro2be is offline   Reply With Quote
Old 01-15-2017, 06:23 PM   #10928
invrtd's Avatar
Trader Rating: 19 (100%+)
Are folks running the servo saver or an aftermarket aluminum servo arm?
https://www.amainhobbies.com/corerc-...-cr192/p268091
SWEEP RACING-----M2C-----TKO BEARINGS-----RW MODS----BELLGATE DISTRIBUTORS
HB D815/E817/D817T/D413
TLR 22T 2.0
invrtd is offline   Reply With Quote
Old 01-15-2017, 06:27 PM   #10929
EbbTide's Avatar
I rarely use a servo saver on any of my cars. I just try to get a full Metal gear servo with decent torque. Haven't stripped a servo yet
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
Old 01-16-2017, 10:57 AM   #10930
invrtd's Avatar
What alum servo horns have the best offset? Read about TLR22 but I want a clamping style horn. I have an aluminum horn but its got a bit of slop in it once I install it on my servo. Tolerances aren't that great.
TLR 22T 2.0
Old 01-16-2017, 11:18 AM   #10931
Seems like you have too much rotation entering the corner. We run on a high bite carpet and typically running 30k front and 15k rear with 1M center. This really slows down the rotation of the car and should help with accel out of the corners.
High bite clay, Tessmans Chitown setup is a good starting point if you want to reference off it.
Old 01-16-2017, 11:39 AM   #10932
snwchris's Avatar
First what type of track conditions... medium bite, high bite, dusty or loamy.
I know for medium/high bite alot of us at our track liked 7-100-5 for diffs and felt planted everywhere especially in the 180s
or tight corner turns and also on the rear hub, using the #3 hole.
The 2k sounds too thin to help plant power to the ground.
snwchris is offline   Reply With Quote
Old 01-16-2017, 12:29 PM   #10933
HB servo arms for the D8 series... either in aluminum or plastic (what I use).
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 01-16-2017, 02:52 PM   #10934
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Maybe you guys can answer, is there a reason this vehicle sells so cheap used? Like, a new vehicle is on the way or something?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-16-2017, 03:02 PM   #10935
EbbTide's Avatar
ThatS an interesting point because I just bought an artr d413 used for $270 a week ago. I was surprised to get it that cheap but it's as if everyone knows something we don't lol
