Like Tree35Likes
Old 12-17-2016, 09:58 PM   #10891
ttr_racer's Avatar
Trader Rating: 22 (100%+)
Originally Posted by rdeppen View Post
Quick question. Getting a new to me 413 in the next week or so. Want to stock up on wheels and tires. It has the 12mm hexs front and rear. What wheels do I need? Standard B5/6 type rears? And what front wheels?
Go to the first page of this thread and start reading, look for the bold print that says "Rims and he rim adapters"
ttr_racer is offline   Reply With Quote
Old 12-18-2016, 08:10 AM   #10892
aeMatt's Avatar
The Exotek D413.
Hot Bodies D413 1/10 4WD Buggy-20161218_105830_resized.jpg
Team Associated\\\\\\Reedy\\\\\\JConcepts\\\\\\Airtronics\\\\\\Upgrade RC
www.rc10.com/www.jconcepts.net/www.airtronics.net/www.upgrade-rc.com
aeMatt is offline   Reply With Quote
Old 12-19-2016, 10:47 AM   #10893
22-4 fronts. b5/b6 rr is fine.
TPJ International
071crazy is offline   Reply With Quote
Old 12-19-2016, 12:13 PM   #10894
snwchris's Avatar
When I had mine I ran the Losi 22-4 and Losi 2.2 rears and usully bought them in the DE wheels style and color unless DE were backordered then got the Losi ones so the colors were consistent.
snwchris is offline   Reply With Quote
Old 12-19-2016, 12:24 PM   #10895
Also, HB D413 wheels fit...
Captain Obvious
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 12-19-2016, 03:01 PM   #10896
MikeR's Avatar
Trader Rating: 15 (100%+)
Thumbs up
Originally Posted by aeMatt View Post
The Exotek D413.
Now that is how you wire up a car
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-19-2016, 06:15 PM   #10897
Looking for a replacement upper Shock standoff. I managed to break one in a bad crash. Does anyone know if there sold separately from the kit?
https://www.amainhobbies.com/hb-raci...114112/p423618
Dave Hoare
Sponsors: Visa....
SuperDaveNT is offline   Reply With Quote
Old 12-19-2016, 08:12 PM   #10898
Trader Rating: 40 (100%+)
Do you mean these?
https://www.amainhobbies.com/hb-raci...115136/p496095
Rick S is offline   Reply With Quote
Old 12-19-2016, 10:46 PM   #10899
Originally Posted by Rick S View Post
That's the ones! TY sir!
Dave Hoare
Sponsors: Visa....
Old 12-20-2016, 02:26 PM   #10900
rdeppen's Avatar
Thank you
rdeppen is offline   Reply With Quote
Old 12-21-2016, 03:17 AM   #10901
The Exotek D413.
How did you remove the orange from your parts?
Looks great!
Roku1200 is offline   Reply With Quote
Old 12-21-2016, 07:05 PM   #10902
aeMatt's Avatar
Roku1200: Thanks! I soaked each orange part in Easy-Off Oven Spray. I found it at Wal-Mart and it's sold in a yellow can. In other online forums and videos, they say it de-anodizes aluminum. In fact, it removes anodizing through corrosion. Just spray the solution into a container and toss each part into the solution for approximately 10 minutes (or more if necessary) but check on each part often and remove each from the solution as soon as the orange is no longer visible. If you leave them in the solution for too long, it begins to significantly corrode the aluminum. I then used a Dremel rotary tool to sand and polish each piece to a high shine.
!!IMPORTANT - READ CAREFULLY!! PLEASE, PLEASE, PLEASE: If you decide to try this technique, use rubber gloves and spray in a well ventilated area (preferably outside). This oven cleaner is SERIOUSLY strong stuff and you MUST take these precautions. It contains sodium hydroxide which will eat away your skin! To be technically accurate, the chemical reaction is called "saponification" meaning when it comes into contact with the fatty tissue in your skin (called triglycerides), it literally turns your skin to soap. Bottom line, stay safe and use the proper protective gear when using this product!
Old 12-24-2016, 08:13 AM   #10903
Default Tech/setup question
I race on high bite. I have copied ronnefalks cactus classic setup and various others. I am wondering what a fix would be for the outside rear wheel lifting in corners on entry. This is typically in a sweeper type turn. What adjustments do you guys think to start with to remedy this?
FLANNIGAN is offline   Reply With Quote
Old 12-24-2016, 08:26 AM   #10904
Maxxingout's Avatar
Trader Rating: 14 (100%+)
Some have gone to a +4mm chassis. Helps plant the car more.
Maxxingout is offline   Reply With Quote
Old 12-24-2016, 10:25 AM   #10905
Anyone running 2mm sway bars on your car, if so which ones did you use?
Dave Hoare
Sponsors: Visa....
