Like Tree29Likes
Old 10-19-2016, 10:01 PM   #10816
Suspended
Trader Rating: 1 (67%+)
Default D413
Is this kit good out of the box I'm picking one up and like to know what parts to pick up for it
Kenhbd8 is offline   Reply With Quote
Old 10-20-2016, 06:42 AM   #10817
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Very good out of the box. I only recommend the Exotek steering rack and center diff cap with spur gear. As another option you can buy the d216 shock pistons so you dont have to drill a set of 2x1.6 and 2x1.7 pistons. If you run that setup. I like tge 12mm hexes so i picked up Avids set but not a must have.
Cameron Kellogg is offline   Reply With Quote
Old 10-20-2016, 12:33 PM   #10818
Originally Posted by rcnewbie418 View Post
Did you get an answer on this? Need o-rings and gaskets too
D216 Diff gaskets
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 10-20-2016, 07:30 PM   #10819
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Thought I would share my latest paint work for my 413.....
Hot Bodies D413 1/10 4WD Buggy-20161011_101050.jpg   Hot Bodies D413 1/10 4WD Buggy-20161010_215416.jpg   Hot Bodies D413 1/10 4WD Buggy-20161011_101057.jpg
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-20-2016, 08:18 PM   #10820
Phillip F's Avatar
Trader Rating: 15 (100%+)
where do you guys buy parts?
Phillip F is offline   Reply With Quote
Old 10-20-2016, 08:20 PM   #10821
Phillip F's Avatar
can't seem to find this center diff cap with spur gear in A main...link?
BTW.. I am trading my roller with a used one and the trader said it's box stock setup. Whats the box setup and what setup is good for clay medium to high bite track?
Old 10-20-2016, 09:04 PM   #10822
nitro2be's Avatar
Nice work. Lot of time to do that. Looks sik
nitro2be is offline   Reply With Quote
Old 10-20-2016, 09:09 PM   #10823
nitro2be's Avatar
You don't need exotek spur but if you must have go to exotek website. Stock set up 10 100 10 diffs and 4 hole pistons. More info in manual. I like 2014 reedy set up and gunsmoke for medium bite. I stated using 50k center to reduce wheel spin.
Old 10-20-2016, 09:41 PM   #10824
Where can we get the replacement differential o-rings part number 66595?
lushrc is offline   Reply With Quote
Old 10-22-2016, 05:27 AM   #10825
What would you guys say with parts support? Is it harder to find parts or has it gotten better?
I see Avid makes a chassis but it looks like its always out of stock. Did they quit making it or is it just in high demand? Any other companies make chassis?
Finally got my new to me buggy and I must say these are beefy.. Very pumped about the design and over all look. Havent been able to run since it cam missing the hex pins but I want to rip apart and set it up to a spec so I know where to go from there..
RcJunky76 is offline   Reply With Quote
Old 10-22-2016, 06:39 AM   #10826
Trader Rating: 18 (100%+)
Originally Posted by Sofa King View Post
D216 Diff gaskets
Thx.. O-rings?
rcnewbie418 is offline   Reply With Quote
Old 10-23-2016, 02:09 AM   #10827
Thx.. O-rings?
P-5
Sofa King Racing
Old 10-23-2016, 05:27 AM   #10828
P-5
So HBS66595 p5 orings (discontinued on Amain) or will other "P5" work? Looks like Durango and kyosho have "p5" orings as well?
Old 10-23-2016, 09:41 AM   #10829
P-5 is a standard metric size, any brand works.
Sofa King Racing
Old 10-23-2016, 08:33 PM   #10830
Has anyone had any luck making changes to this buggy to be competitive on carpet? Or Im I doomed to get a xb4.
