Like Tree31Likes
Old 09-25-2016, 05:37 AM   #10786
What's a good way to keep the plastic pieces on the sway bars connected? My sway bars continually come loose.
Tibbar110 is offline   Reply With Quote
Old 09-25-2016, 05:48 AM   #10787
Trader Rating: 75 (100%+)
I bought brand new sway bar ball cups and then used 3x6mm set screws instead of the 3x3mm set screws that come in the kit. The combination of the new ball cups and longer set screws has never failed me in the year since I installed them. It seems the longer grub screws allow you to put more pressure on the sway bar without stripping inside the ball cups.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 09-26-2016, 05:25 PM   #10788
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I've just taken my center diff out and cleaned the old oil out, regreased the outdrives and seals, and put it back together with fresh oil. I've been using the Exotek Center diff plate for some time and it's always seemed a bit notchy. Anyone tried to fix this or is it just that way? Seems like the center diff is quite a bit more notchy than the rear. I'll be taking them out for rebuild next...
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-26-2016, 05:31 PM   #10789
You should re-shim it so its smooth. Different diff cover might not be the same. Mine is shimmed per instructions and is smooth though.
Jason84 is offline   Reply With Quote
Old 10-04-2016, 12:37 PM   #10790
13Maschine's Avatar
Figured out the issue with my center, diff the screws were just a little bit too tight. Loosened up and re-seated (possibly it wasn't sitting flat too). Now it's like butter
Old 10-05-2016, 07:25 AM   #10791
snwchris's Avatar
I just went thru mine the other day to rebuild for the start of indoor season this weekend and everything still looked good on the car. Rebuilt the diffs and shocks, checked out the outdrives, dogbones and bearing, yep still good.
snwchris is offline   Reply With Quote
Old 10-05-2016, 09:08 PM   #10792
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Won the last outdoor trophy race of the year here, Woo-hoo. Indoor means carpet racing, any updates on the new slipper yet. Worlds was along time ago and they had them then, what's the hold up with production? Looking to copy David's car set up at worlds to see how it works on carpet. Seems running the motor in the saddle position and swapping sides with the electronics worked well.
Cameron Kellogg is offline   Reply With Quote
Old 10-05-2016, 10:26 PM   #10793
mustangkillaz's Avatar
I'm just waiting to see if parts become available from hb. I'm pretty sure I want this over the tlr 2.0
If no answer by next month, it will likely be the tlr for me
mustangkillaz is offline   Reply With Quote
Old 10-05-2016, 11:38 PM   #10794
BigInJapan's Avatar
Trader Rating: 15 (100%+)
Dont know about slipper, but Ronnefalks yatabe setup was about as good as this car can get on carpet. Also tried tessmanns yatabe setup but that was fail. Just note that i wouldnt consider this car competitve on small tight carpet tracks against the newer generation of buggies like the xray or yokomo, on faster larger tracks like yatabe it would probably be a fair bit better
⚡ TEKNO ⚡ OS ENGINE ⚡ KO Propo ⚡
BigInJapan is offline   Reply With Quote
Old 10-06-2016, 07:56 AM   #10795
MikeR's Avatar
You want the HB or the Xray. The belt wheelers are a maintenance minefield.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-06-2016, 10:00 AM   #10796
That was part of the equasion. Just concerned with manufacturer support locally.
Old 10-06-2016, 10:51 AM   #10797
I think xray replacement parts are spendy. Replacing outdrives and drive axles will hurt when the time comes to replace them. I have not been shut down getting parts I need online. Seems Losipartshouse house and Amain have me covered 99% of the time.
Old 10-06-2016, 11:30 AM   #10798
Trader Rating: 137 (100%+)
Really? Have had the 22-4 2.0, and have had to do ZERO maintenance on the belts. And never have to wait months for backordered parts.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-06-2016, 12:41 PM   #10799
Same with the YZ-4...the belts don't require more maintenance than shafts
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 10-06-2016, 01:49 PM   #10800
MikeR's Avatar
Hows the 22-4 front pivot brace bulkheads doing for the guys? j/k haha! I'm not just talking about replacing belts, just working on the belt cars in general are just more of a headache. Have you ever worked on an XB4 in comparison? Easier to work on than a 2wd buggy!
Hot Bodies D413 1/10 4WD Buggy-screen-shot-2016-10-06-1.51.15-pm.png
