Like Tree35Likes
Old 05-25-2016, 08:07 AM   #10696
Trader Rating: 132 (100%+)
Originally Posted by skrichter View Post
Just ordered a few parts, which I hope can change some of the handling characteristics of this wheeler....
Hot Bodies Shock Piston Set 2x1.6/2x1.7mm
Hot Bodies 12mm Shock Bellow Bladder
Hot Bodies Caster Block Set 12.5 Degree L/R D413
Team Orion 2S Carbon Pro Ultra 110C LiPo Shorty Battery (low profile)
what issue are you having? twitchy?
skyline1015 is offline   Reply With Quote
Old 05-25-2016, 12:30 PM   #10697
Kegman21's Avatar
Originally Posted by nmdesertracer View Post
hows the turnout been since 702 went away from clay? My friend should be there at the beginning of next month to race.
Like velcro. Nice not having to clean your car. And air conditioning in Vegas is a must so it helps a lot. Make sure you have him check out the schedule so he does not show up with off-road on an on-road day.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 05-25-2016, 12:31 PM   #10698
Kegman21's Avatar
Parts are starting to arrive at Tower and Amain. Looks like Monday everything will be in. Time to stock up.
Old 05-25-2016, 01:03 PM   #10699
snwchris's Avatar
Originally Posted by omarwashington View Post
what wheels are you guys using?
I usually get the 22-4 wheels when buying the DE colored wheels and even if I get the White or Yellows, since they are cheaper than the HB wheels and plus most LHS carry the 22-4 style wheels
snwchris is offline   Reply With Quote
Old 05-30-2016, 10:29 PM   #10700
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by yzracer758 View Post
Really Thick Shock Oil and stiffer springs, 60wt up front and probably 40wt in the rear.
Anything you can do to help slow down the steering will help also as with the right tires the buggy will be very twitchy and change direction quickly.
Ok I just got done switching my setup to a high bite carpet setup from petite Rc. It feels. Very different than what I am used to. I switched to my schelle alum chasis, 60w rear and 40w front shock fluid, Setup called for 1.3 Pistons but I only had the 1.6 and 1.7 I think they are so I left those. I changed all the shims and hinge pin hangers etc... I am used to a light shock pkg where it would spring back up after compressed. This Package slows it down a lot. I have the spring adjusters turned all the way down and it only springs back up to where the arms are parallel with the ground. Is this what I want?
I also went to 3k rear, 20k front and 60k center on the diffs.
And I got the pinpoint tires and ran them on Saturday (with the old clay setup) and wow that thing sticks to the track
Like crazy.
I am also wondering about my current shock orings. i noticed that the rear shocks had black gook on the body and lower cap the other day so when I took them apart I noticed the previous owner had installed what looks like traxxas x-rings. Do those work better than the stock HB orings? I hate leaky shocks. The front also have the xrings but I didn't notice any leaking from the fronts, just the rears. So I was going to order HB orings but wasn't sure if I was downgrading by installing those and if I should just get new xrings
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 06-01-2016, 06:25 AM   #10701
Originally Posted by Billy View Post
Anyone used the new Exotek rear hubs? Any opinions? Does anyone know How the vertical ball cup locations on the hub correspond to the horizontal stock positions. I know they give you a spacer and a recommendation for the ball stud. Does the inside ball stud location correspond to the #2 location on the stock rear hub?
does anyone have any experience with the exotek rear hubs?
Old 06-02-2016, 12:09 PM   #10702
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I'd love to hear some feedback on the floating servo mount, thoughts and feedback please?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 06-02-2016, 12:10 PM   #10703
Trader Rating: 125 (100%+)
I have been wondering the same things. Anyone?
Chris Gierse is offline   Reply With Quote
Old 06-02-2016, 12:35 PM   #10704
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi,
As noted on the product page- both holes matches the position of the stock D413 hubs.
http://www.exotekracing.com/d413-d21...-hub-set-7075/
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-02-2016, 12:40 PM   #10705
MikeR's Avatar
Not specifically the D413 but 4wd in general, I feel floating mounts are inconsistent. The more traction goes up, the more the servo flexes and doesnt feel centered due to the front tires pulling on the links... This is not as noticeable when traction is lower. Pretty much feels like a servo saver FWIW.
Old 06-02-2016, 01:06 PM   #10706
Originally Posted by MikeR View Post
Hi,
Do you use the shim to match the upper position on the hub and no shim to match the the lower position?
Old 06-02-2016, 01:17 PM   #10707
MikeR's Avatar
Correct
Old 06-02-2016, 01:38 PM   #10708
Correct
Thanks!
Old 06-02-2016, 02:23 PM   #10709
Kegman21's Avatar
Like crazy.
Some people did run the traxxas in the past but the newer HB work great. With carpet remember the lower your car the better it corners and stays planted. LCG if you have to much bite consider removing a row of pins off the outer portion of your rear tires.
Old 06-08-2016, 12:37 PM   #10710
Sorry, but I can't seem to get a straight answer with the search function and I need to place an order ASAP so I have wheels/tires this weekend. I don't have the D413 yet but I bought one used and want to run it this weekend if possible.
Will any 12MM Hex wheel work for this?
Jconcepts Mono (R)
B5M Rear
etc.
https://www.amainhobbies.com/search?...7_3827&lg=fk37
https://www.amainhobbies.com/search?...l%204wd%20rear
I did a little more searching and it appears that TLR 22-4 fronts work well, and just about any 12mm rears work well.
Is that accurate?
40yoCaliRacer is offline   Reply With Quote
