Like Tree28Likes
Old 05-21-2016, 03:14 PM   #10681
Kegman21's Avatar
Originally Posted by YoG View Post
https://www.amainhobbies.com/sworkz-...800afy/p267312
Last wing you will ever need for this buggy. Make sure you get the no hole version, measure twice and drill your holes and trim the wickerbill.
Available in Black Yellow Orange White no holes
Order placed thanks for link.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 05-22-2016, 03:36 PM   #10682
Default How are the Aluminum Shock Caps Installed?
I have the aluminum shock caps on order. I see how most of it is put together. Are there any guides?
http://hpiracing.world/en/part/114112
Tibbar110 is offline   Reply With Quote
Old 05-23-2016, 12:45 PM   #10683
Slapjack's Avatar
Trader Rating: 19 (100%+)
I just took my D413 out for the first time on Saturday. I also raced on a carpet track for the first time ever. I didn't have the right tires so I used my dirt webs. Needless to say I was sliding quite a bit. One guy let me use his rear proline pinpoint tires which made a big difference, but the car really seemed to be pushing a lot (I still had the dirt webs on the front). Will that be corrected once I get a pair of pinpoints on the front as well?
Also what is a good setup to run for carpet? I wasn't planning to run on carpet when I got the buggy so I set it up originally to the gunsmoke setup I believe.
I am running the Schelle extended carbon chasis right now but I also have the aluminum extended chasis. Would the aluminum chasis be better for carpet?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 05-23-2016, 12:52 PM   #10684
Trader Rating: 130 (100%+)
I would use the Aluminum chassis for carpet, less chassis flex. Also, once you get the front carpet tires, you will have no issues with pushing.
skyline1015 is offline   Reply With Quote
Old 05-23-2016, 12:59 PM   #10685
Slapjack's Avatar
I was hoping the tires would fix that. Any other changes that should be made to run on carpet?
Old 05-23-2016, 01:04 PM   #10686
i have never driving on carpet. but from what i have read, you need to change ride height and shock package. I would follow one of the setups from petit rc
Old 05-23-2016, 02:11 PM   #10687
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Really Thick Shock Oil and stiffer springs, 60wt up front and probably 40wt in the rear.
Anything you can do to help slow down the steering will help also as with the right tires the buggy will be very twitchy and change direction quickly.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 05-23-2016, 07:27 PM   #10688
Kegman21's Avatar
I keep my ride height around 17 and red rear springs. The best thing is tires.
Old 05-23-2016, 07:53 PM   #10689
Trader Rating: 137 (100%+)
Possibly limit dual rate on the radio like we do in on road?
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-23-2016, 08:26 PM   #10690
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I've raced at 702 in Vegas on their Off Road Carpet setup. Didn't have the alum chassis at the time but when I go back I will.
Pinpoints are like velcro on carpet. You will have more traction than you will need. Way more. You will experience traction rolling.
Here's the changes I made on my last visit (from what I can remember)
Chassis roll helps to create more traction, in carpet you don't need this. Imagine you are on velcro. Keep the car flat.
Low ride height. I typically run 20mm or so for Offroad. I'd go to 17mm here as a place to start.
Stiffer Roll bars front and rear. Keeps the car flatter and thus less traction rolling.
Wider in front and rear. I use the avid wheel shims. Makes it easy to adjust.
Stiffer Springs front and rear, again keeping the car flat.
Negative Expo on my radio. I use this for dirt too, but it's amazing on Carpet or for On Road. I was down to -25% on my 4PX.
Things I plan to change next time:
Alum CHassis
Yatabe Carpet Springs
Diff Oil, 300K or at least 100K.
That's all I got for now
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-24-2016, 04:53 AM   #10691
Slapjack's Avatar
Thanks for all the tips guys. Good stuff
Old 05-24-2016, 03:16 PM   #10692
omarwashington's Avatar
what wheels are you guys using?
RCCARS!
omarwashington is offline   Reply With Quote
Old 05-24-2016, 05:19 PM   #10693
Kegman21's Avatar
Alum CHassis
My home track is 702. I shave the first row of pins on the rear also. But almost everything else you've said is the set up for the few of the D413's that I've seen run in addition to mine at the track. Plus they carry parts when HB sends them.
Old 05-24-2016, 08:29 PM   #10694
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
hows the turnout been since 702 went away from clay? My friend should be there at the beginning of next month to race.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 05-25-2016, 08:00 AM   #10695
skrichter's Avatar
Send a message via AIM to skrichter
Just ordered a few parts, which I hope can change some of the handling characteristics of this wheeler....
Hot Bodies Shock Piston Set 2x1.6/2x1.7mm
Hot Bodies 12mm Shock Bellow Bladder
Hot Bodies Caster Block Set 12.5 Degree L/R D413
Team Orion 2S Carbon Pro Ultra 110C LiPo Shorty Battery (low profile)
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
