Like Tree42Likes
Old 02-17-2016, 05:21 PM   #10516
Slapjack's Avatar
Trader Rating: 19 (100%+)
I also wanted to ask about a couple cosmetic things. Does anyone know if the shock spring adjuster collar and the lower cap and maybe even the spring perch from the tcxx touring car will work on the d413? Also the clamping wheel hexes. If you search hot bodies purple on Amain all those parts come up. I want to make all the orange pieces purple and I've seen cars wth that but wasn't sure if they had them re anodized or if they bought purple parts. Any help with that?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 02-17-2016, 07:40 PM   #10517
Originally Posted by Slapjack View Post
Thanks... I actually just went home and looked at the setup sheet and I did sort of make a couple small changes from the gunsmoke setup. I am at 10 deg kickup, 0 deg anti squat. diffs are 7/100/3. I am going to try the 100k just cause it's already in there and take the 50k and 60k with me to the track. Just so I can try them all to feel the difference. I figured 100k was a little heavy tho.
I know in the back of my head this is just way too high but for my X-ray xb4 a team driver swears I need to be running 500k in the cd. I put it in just to try. He says they run 1,000,000 cst normally and 500k for blown out tracks. Has anyone ever run anything that thick before? I've never seen it done but it seemed like quite a few ppl on the xb4 thread run real thick fluids.
I started running 200K in mine when traction was up last year; then at the track layout change I left it at 200K with low traction and the buggy was still great. Only changed ackerman and springs. At 60K and 100K the buggy was controllable but sluggish and slow. Potentially, the 60K and O degree anti-squat may leave you pushing into turns with little chance of the buggy responding until you have blown through the turn....guess you'll have a chance to try it out and see how it goes...
Losi 22 3.0 / Hot Bodies D413 / Xray XB4 '16 / Tekno SCT410.3 / Tekno EB48SL / Losi SCTE 3.0
Troyster is offline   Reply With Quote
Old 02-17-2016, 08:38 PM   #10518
Like this?
Allen Drebi is offline   Reply With Quote
Old 02-17-2016, 08:50 PM   #10519
Slapjack's Avatar
Hmm, ok so I'l am for sure going to try the 100k I have in it now but what about the 0 anti squat? I am not real clear on what anti squat effects. What is it exactly?
Old 02-17-2016, 09:15 PM   #10520
nitro2be's Avatar
Anti squat effects the rear of car as its titled, prevent rear from squatting to much under acceleration so your not dragging chassis. 1 to 2 degree typical. More anti squat will make car spring and jump easier,and less will improve traction as long as your not dragging chassis . I've never seen a set up sheet with 0 anti squat before. Hope that helps little.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 02-17-2016, 10:10 PM   #10521
Slapjack's Avatar
Old 02-17-2016, 10:11 PM   #10522
Slapjack's Avatar
Originally Posted by Allen Drebi View Post
Like this?
Pretty much... What are those fasteners? I've never seen heads like those. Is this your car?
Old 02-18-2016, 04:56 AM   #10523
snwchris's Avatar
If it's a different color, someone might have had them Anodized to strip the orange and change to what ever color you want. I think the most popular is place that does it is Carolina Custom Anodizing.
snwchris is offline   Reply With Quote
Old 02-18-2016, 04:58 AM   #10524
snwchris's Avatar
As for the Center diff fluid, I run on med-high bite and really like 7-100-5.
I've tried lower center diff fluid like 75 and 60 but didn't like how it felt and actually my lap times dropped down some.
Now when I ran outdoors I switched to 7-80-5 and felt pretty good
Also IMO, I think tires play a BIG part of the setup, so if your not on the right tires as well
it can feel different and sometimes if new tires it takes a few battery packs ran thru with the new tires
for them to feel like there broke in.
Old 02-18-2016, 08:00 AM   #10525
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Carolina Custom Anodizing is the place to go. Jason there does great work, you can PM me for his Phone Number if you are interested.! The purple hardware I get from: www.fastener-express.com
Hot Bodies D413 1/10 4WD Buggy-12493421_1222950957733910_5062748749006648627_o.jpg
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics |
Jeremy Potter
yzracer758 is offline   Reply With Quote
Old 02-18-2016, 11:51 AM   #10526
ogmudbum's Avatar
**EDITED**
Please keep for sale stuff in the correct forums.
Thanks, Brad
ogmudbum is offline   Reply With Quote
Old 02-18-2016, 12:36 PM   #10527
Slapjack's Avatar
Thanks! This might be asking a lot but does anyone happen to have a list of all fastener sizes and lengths for the D413? I am not home so I don't know if the manual has all the sizes listed or not but I would prefer to not have to remove every screw and measure.
Old 02-18-2016, 01:16 PM   #10528
snwchris's Avatar
The manual has all the sizes and shows based on parts bag and area being built.
Old 02-18-2016, 02:23 PM   #10529
nitro2be's Avatar
Download the Manual from hpi website on your work computer like most of us.
Old 02-19-2016, 06:15 AM   #10530
wildfire86's Avatar
Has anyone tried AE shocks on this platform?
I must be doing something wrong building the HB shocks. I've put the bladder top on and bled the shocks...do they ever stop leaking out of the little hole? I'm sure it's operator error somewhere. Please guide me in the correct direction.
Doug Hudson
Beachline Raceway / 386 Raceway
wildfire86 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
