Like Tree31Likes
Old 02-08-2016, 10:05 AM   #10471
mvrk28's Avatar
Originally Posted by Slotmachine View Post
Definitely sounds like a build error..........mine is on its second season on high bite surfaces and no noise or stripping out. Check the bearings for wobble too..........
Most definitely not a build error, built the car per the manual and ran it for almost a full season before this started happening.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-08-2016, 10:22 AM   #10472
wittyname's Avatar
Originally Posted by mvrk28 View Post
ordered a new front gear box set as mine have been stripping every trip out. I ordered new shims as well gonna go down from where it was. Last straw for this car which is a bummer because I love this car. But I'm not running a car I can't rely on. Looking at the DEX410V5...
It's a real bummer man, I ordered some smaller shims though gonna see if I can get some more thread in there and see what happens. Hoping it all works out and the D413 stays.
So ... Just to clarify .... You ran the car for a whole season with no front end issues , then all of a sudden it stripped out ? The diff and bevel gear stripped ? what exactly was damaged ? Your going to shim it with smaller shims ? to get more "thread " in it ? what are you saying here , what threads ? How many times has this happened ? What do you think caused the damage ? If it lasted a year , and nothing ( NOTHING ? ) changed , and now your having problems then I assume you have a theory , share it with us so we know
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 02-08-2016, 10:36 AM   #10473
mvrk28's Avatar
My issue is where the ball stud inserts in to the top half of the gear box. These have been stripping for me non stop. The smallest crashes have been stripping them, getting one trip to the track and the ball stud has pulled out of by the end of the trip. And the last two times the crashes have not been anything that would concern you about breaking. The current layout at my track doesn't have a jump on it that is capable of breaking this car. I am thinking about trying all new ball studs as well, as I said I really don't want to ditch this car.
VANT LIPOS
Old 02-08-2016, 10:59 AM   #10474
wittyname's Avatar
Had no idea you were originally talking about ball studs stripping out ...
I have always run the longest ones that will fit the set up I want to run , and I actually use a little ca glue on the threads . Also, using a grub screw in the holes your not using will keep the plastic from deforming too .Im sure you will have this sorted out soon
Josh W.
Old 02-08-2016, 01:29 PM   #10475
Slapjack's Avatar
Trader Rating: 19 (100%+)
Just wondering if anybody is using another manufacturers shock shafts? Amain and Tower are out of stock of the front shafts. I haven't bent one yet cause I am just rebuilding the used one I bought but I read front shafts can be troublesome and wanted to get a couple just as back ups. What are other spares I would want to have on hand? I also saw the spur may strip easily? Is the exotek spur and alum mount plate a good fix for that issue?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 02-08-2016, 01:36 PM   #10476
Trader Rating: 131 (100%+)
stormerhobies has them in stock
http://www.stormerhobbies.com/cgi-bi...l?pn=HOT113139
skyline1015 is offline   Reply With Quote
Old 02-08-2016, 02:44 PM   #10477
Trader Rating: 75 (100%+)
Originally Posted by skyline1015 View Post
Abosolute Hobbyz has them in stock too: http://www.absolutehobbyz.com/search...113139&search=
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 02-08-2016, 04:14 PM   #10478
Front shock shafts,m3x20 screws , shock standoffs, plastic shock kit,
Exotek spur/extra spur and that should be it
boggiii is online now   Reply With Quote
Old 02-08-2016, 04:23 PM   #10479
jwood7's Avatar
they make ballstuds with longer threads. sounds like u need them
jwood7 is offline   Reply With Quote
Old 02-08-2016, 06:04 PM   #10480
Slapjack's Avatar
Cool... Thanks for the info guys
Old 02-08-2016, 06:50 PM   #10481
Slapjack's Avatar
Will the exotek spur work with the stock mounting plate or should I get the whole exotek unit with the aluminum mounting plate?
I also had a question about shock Pistons. Seems like everyone runs the 1.7 2 holes in the rear and 1.6 in front. I was looking at the vrp piston and they say the 1.6 is for high grip. I am going to run 1.7 rear but does anyone run 3 hole 1.4 or 1.3? My tracks are low grip, medium at best.
Old 02-08-2016, 07:37 PM   #10482
Yes the exotek spur is the same size as the stock spur. The aluminum diff cap does work as a heatsink to help remove heat from the center diff / motor plate which is nice. Other than that there is no real benefit to the exotek center diff mount other than it looks nice. I do wish exotek offered black for the D413 parts it would be a great option Mike !!
More good parts to get would be front arms, rear arms, hingepin set (I have bent 3 fronts so far), Front shock tower mount braces I think most people quit breaking must have been some sort of silent revision but I have 2 just in case. Also keep 1 Rear shock tower mount, Front and rear shock shafts, few spare sets of traxxas x-rings for the shocks, front diff case, Rear hubs I got T-Boned and one broke so I ordered 2 sets (Exotek will be releasing aluminum ones soon I hope), Spare set of bearings and possibly front/rear shafts/axles if you want to spend the money, I also keep 1-2 extra spur gears for the exotek setup.
It really depends how hardcore you are going to race and how bad of a day its going to be when you cant finish.
Jason84 is offline   Reply With Quote
Old 02-08-2016, 09:14 PM   #10483
I've used Kyosho shafts in a pinch. I forgot the exact length I bought but it was just to get through the night
CaseyD is offline   Reply With Quote
Old 02-09-2016, 06:52 AM   #10484
Lexicus's Avatar
I've had this issue on mine. Ended up going with longer AE ballstuds (because I'm running AE Cups).
Lexicus is offline   Reply With Quote
Old 02-10-2016, 04:39 AM   #10485
I run stock 13.5 class, on an medium sized indoor track high grip dirt, with a long straight into sweeper. I am looking at buying a schelle+4. Should I buy carbon or aluminum or is the stock chassis better?
Sotien is offline   Reply With Quote
