Like Tree31Likes
Old 02-03-2016, 11:35 PM   #10456
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I've just finished installing my new Schelle +4mm chassis kit. Still need to reinstall the electronics but it's nice that the kit includes a longer top deck, so it's a complete kit for significantly less than the HB +6mm chassis and new top front and rear deck. It looks super solid and very high quality. I'm sure the longer chassis will help the car fly a little more consistently and rotate just a little less.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-04-2016, 04:53 AM   #10457
snwchris's Avatar
I have the carbon Schelle chassis and so far one of the best upgrade for the D413. It handles the rough stuff awesome and flies great. Our track is medium sized with some tight 180s and does perfect handling those as well.
When I re-installed my electronics I put my ESC in the rear behind the motor, my RX up front same side as motor and then servo and TP in front of the battery. Also I run my battery in vey last hole so farthest back and the car is super dialed and planted.
snwchris is offline   Reply With Quote
Old 02-04-2016, 12:02 PM   #10458
lala4fire's Avatar
Default Lost sun gear washer
While rebuilding my center diff I lost one of the washers behind the sun gear(small one). HB does not sell just the washer. I would have to buy a whole diff!! Any suggestions what might work. Thanks.
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 02-04-2016, 12:23 PM   #10459
klaymon's Avatar
Trader Rating: 71 (100%+)
AMain sells all kinds of diff shims: http://www.amainhobbies.com/search?s...s&fb=209&lg=fb
Just measure one of the factory ones with your calipers and see if any of those match. These are the just the ProTek ones that list the sizes. There are others that I'm sure could match.
klaymon is offline   Reply With Quote
Old 02-04-2016, 12:23 PM   #10460
wittyname's Avatar
X ray , kyosho, and yokomo tend to sell parts like that individually . You may have some luck just ordering 4 of them
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 02-05-2016, 04:03 PM   #10461
rc-racer75's Avatar
Trader Rating: 26 (100%+)
OK guys don't have a track close. Does any one chassis work for all conditions? Like a loose loamy track, med to high bite and carpet/astro.
FL 22SCT RS GEn2/w Gen2 17.5, FL 22SCT RS TP 10.5
22-4 Sanwa Vortex, gen2 6.5, HB D413 r10pro orion 6.5t
22 3.0 Tekin RSgen2 TP 9.5, 22 3.0 RS Spec D4 17.5
M12 controls them TrackTime Reno or 702Rcraceway!!
rc-racer75 is offline   Reply With Quote
Old 02-05-2016, 04:10 PM   #10462
Trader Rating: 131 (100%+)
The schelle +4 carbon has worked for me on a small high bite and med to large outdoor track. I installed the +4 aluminum chassis but have not tried it yet.
skyline1015 is offline   Reply With Quote
Old 02-05-2016, 06:19 PM   #10463
rc-racer75's Avatar
Thanks for the input I have schelle CF chassis, but got another buggy comiong with the aluminum schelle chassis. Let me know how it works for you. I also have an avid chassis just for the option.
Old 02-06-2016, 02:12 PM   #10464
ogmudbum's Avatar
New guy got a question for you guys. Just built the car and everything runs pretty good except sometimes when im on full throttle from the start or on something high grip like the road. The car will accelerate at a much slower rate and make a higher than normal high pitch squeal noise. If I back off the throttle a bit it catches again and just takes off flying like it should. Any thoughts?
ogmudbum is offline   Reply With Quote
Old 02-06-2016, 02:39 PM   #10465
mvrk28's Avatar
ordered a new front gear box set as mine have been stripping every trip out. I ordered new shims as well gonna go down from where it was. Last straw for this car which is a bummer because I love this car. But I'm not running a car I can't rely on. Looking at the DEX410V5...
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-06-2016, 04:20 PM   #10466
rregl0612's Avatar
Trader Rating: 33 (100%+)
check for dust around the spur? sounds like your mesh might not be set. also double check the shimming in the front and rear diffs. ensure they are to the manuals spec.
if its the spur.. might as well buy the exotech. and make sure you placed the set screw in the motor mount that acts as a hold down screw.. I missed this step and only this step when building and it cost me 2 spurs.. but has been solid since finding it...
Thanks to my sponsors, My Wallet, endorsed by Some crazy pharmaceutical corporation!!!
Member of "The White Wheel Mafia!"
Bumps and Jumps, Pitstop Hobbies, LCRC!
rregl0612 is offline   Reply With Quote
Old 02-06-2016, 05:37 PM   #10467
ogmudbum's Avatar
There is no dust she is brand new. My set screw was not set actually soo thank you, but i just took it for a spin after tightening that down and still the same. I did all your other recommendations earlier today... Thank you
Old 02-08-2016, 05:43 AM   #10468
snwchris's Avatar
Dang, that sucks and sorry to hear. I haven't seen or heard of any issues with them in my area and there are about 6 to 8 of them at our track alone.
Still on the original set here and thats been well over a year now even with a lot of outdoor running on some 1/8 tracks too
Old 02-08-2016, 05:55 AM   #10469
mvrk28's Avatar
It's a real bummer man, I ordered some smaller shims though gonna see if I can get some more thread in there and see what happens. Hoping it all works out and the D413 stays.
VANT LIPOS
Old 02-08-2016, 09:16 AM   #10470
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Definitely sounds like a build error..........mine is on its second season on high bite surfaces and no noise or stripping out. Check the bearings for wobble too..........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
