Like Tree31Likes
Old 01-14-2016, 06:52 PM   #10396
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default Not on current topic
For those running the Sworkz wing which I happen to love, if you want quick access to your rear towers here is an easy way to get at em when running the wing in high (mounts up).
I was experimenting with options of not cutting this wing down following some old school 1/8 habits when I found this and felt like Sharing
Just drill/ream 2 holes at the corner of the raise and your gold!!
rregl0612 is offline   Reply With Quote
Old 01-14-2016, 10:46 PM   #10397
Originally Posted by MattPR8 View Post
I'm running close to David Ronnefalk's world's set up. I've got the HB + 6mm chassis (he was using a redworkshop version), 60wt front shock oil, no 3 steering plates, 10k front diff oil and 5k rear diff oil.
If I was gonna change anything, I would come down to 30k centre diff, as I'm pulling wheelies at the moment with 50k.
The setup sheet I got said he was running 1 million in the center diff! Another guy at our track was running his set up with 500,000 in the center and it was dialed.
Dave Hoare
Sponsors: Visa....
SuperDaveNT is offline   Reply With Quote
Old 01-15-2016, 04:05 AM   #10398
Just fitted the 2.0 sway bar from d8.
Only needs bending and cutting and the ends.
Will hopefully try it this weekend☺
Edit: i use the switch sway bar holders with some shortes link i had laying around. Also mounted them the other way in rear so that they dont bind with the upper link
Hot Bodies D413 1/10 4WD Buggy-20160115_125042.jpg   Hot Bodies D413 1/10 4WD Buggy-20160115_125112.jpg   Hot Bodies D413 1/10 4WD Buggy-20160115_125118.jpg   Hot Bodies D413 1/10 4WD Buggy-20160115_132930.jpg
HB D815, D413, D216. Mugen mbx7r. Xray X1, XB2 CE 17
boggiii is offline   Reply With Quote
Old 01-15-2016, 08:14 AM   #10399
Even with 50k in the centre of mine, when I launched at the start of my final I did a back flip on the spot. Once moving, 50k was fine.
MattPR8 is offline   Reply With Quote
Old 01-15-2016, 07:47 PM   #10400
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
How many of you folks here have upgraded to the +6mm chassis? pretty expensive upgrade with the seperate top decks, especially when compared to the complete kit from schelle although it's 2.5mm and only +4mm....Comments?? Anyone compared the two??
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 01-15-2016, 09:17 PM   #10401
YoG
YoG's Avatar
Yo RedBMaster
Don't bother with them they will snap very easy. Just buy a bunch of the stock ones and do not locktight them. There were designed to bend as Torrence has stated on this forum.
XRAY XB2ce/AE T5M/AE SC5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
Old 01-16-2016, 03:50 AM   #10402
Hi, I'm trying to rebuild my diff and when I look at ronnefalk worlds setup, it says slipper. What does it mean? Thanks..
N15M0 is offline   Reply With Quote
Old 01-16-2016, 06:50 AM   #10403
rc-racer75's Avatar
Trader Rating: 26 (100%+)
Originally Posted by 13Maschine View Post
Traxxas X Rings are awesome. Using them in my RB6 as well as my D413.
So are the traxxas x-rings the only ones that will work? Got some 22 2.0 and associated x-rings. Waiting on my car.
FL 22SCT RS GEn2/w Gen2 17.5, FL 22SCT RS TP 10.5
22-4 Sanwa Vortex, gen2 6.5, HB D413 r10pro orion 6.5t
22 3.0 Tekin RSgen2 TP 9.5, 22 3.0 RS Spec D4 17.5
M12 controls them TrackTime Reno or 702Rcraceway!!
rc-racer75 is offline   Reply With Quote
Old 01-16-2016, 02:15 PM   #10404
Originally Posted by skyline1015 View Post
I am assuming they are running on carpet or Astroturf.
i have a question, i'm getting one of these cars, i have some 50C 400mah cells and a tekin rs gen 2 from my 2wd. is this ok in a 4wd car?. please forgive a stupid question i'm a 1/8th on road guy.
who cares what the kardashians are doing
5italkart is offline   Reply With Quote
Old 01-16-2016, 02:19 PM   #10405
That is an, as yet, unreleased slipper clutch. If you look at Tessman's world's set up, you will see a suggested alternative.
Old 01-16-2016, 05:40 PM   #10406
RedBMaster's Avatar
Originally Posted by YoG View Post
Yo RedBMaster
Thanks for the input! I need some loctite as I had one back all the way out during practice. I do go ahead and buy a couple sets of screws tho.
RedBMaster is offline   Reply With Quote
Old 01-16-2016, 07:47 PM   #10407
13Maschine's Avatar
Smile
I think the shock shafts on TLR are a little larger, 3.5mm if I remember correctly.
Old 01-16-2016, 10:34 PM   #10408
Thanks. So is 15k front 50k center and 5k back?
Old 01-17-2016, 07:47 AM   #10409
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
anyone how if the D812/D815 shock stand offs will work on the D413 aluminum shock caps?
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 01-17-2016, 08:56 AM   #10410
That's what I was running and for me the car was very neutral.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
