Hot Bodies D413 1/10 4WD Buggy
yup ... .0708 ( I missed the zero) rounded up
Fyi the losi scte sway bars require 2 simple bends and a trim and they fit perfectly. I got some from a guy at the track who said that he never uses the skinny ones and gave them to me 1.8mm and 2mm
No idea of part number. I belive front and rear are the same.
Hey. Looking to get a D413.. Are there any aftermarket parts I should get right away for the build?
Aluminum shock caps and exotek steering rack. Avid carbon arm inserts are a maybe. I also added the avid servo mount and exotek spur gear. I use ae shock springs.
What's the consensus on using Titanium screws for the hinge pin pills? Or is there a better brand of screws to use?
Has anyone noticed a big difference running the avid aluminum chassis compared to the Schelle extended chassis besides the length difference?
If I was gonna change anything, I would come down to 30k centre diff, as I'm pulling wheelies at the moment with 50k.
Not on current topic
For those running the Sworkz wing which I happen to love, if you want quick access to your rear towers here is an easy way to get at em when running the wing in high (mounts up).
I was experimenting with options of not cutting this wing down following some old school 1/8 habits when I found this and felt like Sharing
Just drill/ream 2 holes at the corner of the raise and your gold!!
I'm running close to David Ronnefalk's world's set up. I've got the HB + 6mm chassis (he was using a redworkshop version), 60wt front shock oil, no 3 steering plates, 10k front diff oil and 5k rear diff oil.
The setup sheet I got said he was running 1 million in the center diff! Another guy at our track was running his set up with 500,000 in the center and it was dialed.
