Like Tree28Likes
Old 12-13-2015, 08:55 PM   #10261
nitro2be's Avatar
Originally Posted by rcgod View Post
I have both 12.5 and 15 and will be trying them out tomorrow. I'll let you know how they worked.
Any good information on caster experiment?
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 12-14-2015, 03:04 AM   #10262
I run dual stage pistons, with the B5 shock caps so they don't pop off. I absolutely love the D413 it is way more durable than any other 1/10 4x4.
Ledonne99 is offline   Reply With Quote
Old 12-14-2015, 06:03 AM   #10263
Originally Posted by PetRock View Post
I've searched the thread but didn't find a response: what shock bottoms/eyelets can I use instead of the 2 included in HBS112792? (I already have way more than enough of the other shock parts included )
Grab a T-Bone Racing bumper. It's low profile but enough protection I haven't needed to replace a shock end since using it.
I too have lot's of the spare shock parts from those bags...
GimpyGolden is offline   Reply With Quote
Old 12-14-2015, 10:59 AM   #10264
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
Are you running RC Shox or VRP dual stage? Something else perhaps?
Thanks in Advance!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 12-14-2015, 03:53 PM   #10265
I don't think there are any other options. The only thing I have broken on my buggy so far is 2 shock shafts from extremely hard impacts both broke off inside the end and I couldn't get them out. I bought like 3 of those bags and I hate throwing away all those parts. If I would have known that I would have stuck with the plastic shock caps because now I have 6 spares ! I emailed HPI directly trying to see if I could even buy large quantities of them and they said no.
Jason84 is offline   Reply With Quote
Old 12-14-2015, 07:25 PM   #10266
Losi 22 shock eyelets worked for me . Hope that helps
vanpaassen is offline   Reply With Quote
Old 12-15-2015, 07:01 AM   #10267
13Maschine's Avatar
Hey All, I've been running my D413 for about six months now and it's always had a the typical loud transmission sound. I had spent some time shimming it when I first built it but since I've upgraded to new Avid Ceramic bearings I thought I'd try to get it smoother and quieter. I've been able to make the center diff to the front wheels buttery smooth. Unfortunately the rear has actually gotten worse. I've tried all sorts of shim combinations, from none (let it float) to tight and as loose as possible. There is always a specific section of gear that grinds. It's especially bad when you fully assemble the rear, even after careful loosening of all the screws around the rear case as to not overtighten things.
I've read through most of the comments I could find from way back but I'm hoping new thoughts and ideas are also around. Thank you in advance.
Looks like I will probably order a new transmission case and gear set just in case.
Cheers!
Old 12-15-2015, 09:45 AM   #10268
RENOV8R's Avatar
Could be from overtightening the diff itself, not the case.
BTW ceramic bearings and offroad don't mix IMO
RENOV8R is offline   Reply With Quote
Old 12-15-2015, 10:46 AM   #10269
Lexicus's Avatar
Trader Rating: 19 (100%+)
Associated work too - I run their caps, perches and eyelets because I had them from other cars...
Lexicus is offline   Reply With Quote
Old 12-15-2015, 12:39 PM   #10270
wittyname's Avatar
Should move this helpful bit of info right to the front page ...
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 12-15-2015, 03:08 PM   #10271
Originally Posted by N15M0 View Post
I'm running mostly on mid bite AstroTurf, does upgrading to aluminium chassis (like avid) makes the car handle better on AstroTurf.
I too race on Astro and gave the Schelle +4 extended aluminum chassis a try. This chassis did help, it felt like it was more stable and more predictable going into turns and exiting as well. On straights it tracked better and overall took some of the edge out. Along with the #5 ackermann my D413 felt it's best so far on high grip astroturf.
Vincent_Diesel is offline   Reply With Quote
Old 12-15-2015, 07:37 PM   #10272
I used the associated ones but the spring perch is very lose on them and they are not as deep as the HB ones you cant thread the shock shaft in very far.
Old 12-15-2015, 10:07 PM   #10273
13Maschine's Avatar
Smile
I've been able to resolve most of it, seems that some of the titanium screws are just a touch longer than the steel replacements and this can cause binding. I'll have to double check the diff to make sure I didn't over tighten it as well, that would probably cause it to be a bit out of round. It seems mostly due to the Lunsford screws being too long as once I went shorter it became much looser.
Why don't you like ceramics in off road? I've been running them for quite a while and they've been solid. I do clean them though, with citrus based cleaner using an ultrasonic bath. Essentially the avid cleaning method....
Thanks for your ideas!
Old 12-15-2015, 10:12 PM   #10274
13Maschine's Avatar
If I may take a small poll in the thread here of who is running a longer chassis and which one? I'm leaning towards the graphite chassis to keep the weight to a minimum.
Thanks in advance!
Old 12-16-2015, 07:02 AM   #10275
rcgod's Avatar
Trader Rating: 27 (100%+)
Unfortunately no. I wasn't able to make it to the track. Hopefully this weekend.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
