Like Tree42Likes
Old 11-29-2015, 06:27 PM   #10201
Originally Posted by Vincent_Diesel View Post
From RENOV8R a few pages back.
Exotek Part # 1535
Xray Part # XRA362290
Yes used on the front hubs and/or stock ackerman bar. I used 4 in total for D413 C-hub.
thank you. i just got a 8.5 turn what pinion should i start with?
DIRT DIGGER is offline   Reply With Quote
Old 11-30-2015, 07:54 PM   #10202
Trader Rating: 75 (100%+)
Originally Posted by MiQ View Post
Does anyone know ballstuds with long threads? When I was driving with 4mm spacers in front links, inner stud ripped off from the gearbox. So I would need ballstuds with longer threads for more secure.(originals are 15mm?)
Funny you should ask this, I just bent the rear inner ballstud when it ripped out of the rear carbon fiber camber link mount I had. You can't find the stock HB part number (HBS112983) anywhere in the U.S, which really pisses me off, but I digress. The longest ball stud this car uses is 10mm long. The actual dimensions are 4.8mm (ball diameter) x 5mm (height from top of ball to shoulder) x 10mm (thread length). After some extensive research I found that Losi makes a 4.8mm x 10mm long ball stud that works great, the part number is TLR6023. The only difference is that the TLR ball stud is about 6mm from the top of the ball to the shoulder because the shoulder is about 2mm in height. The HB ball stud shoulder is only about 1mm in height. I used these on my car this weekend and they held up great.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 11-30-2015, 08:22 PM   #10203
http://www.lunsfordracing.com/mm5/me...gory_Code=BALL
These here as well.
Jason84 is offline   Reply With Quote
Old 12-01-2015, 08:23 AM   #10204
RENOV8R's Avatar
Originally Posted by Jason84 View Post
Yes they are. I have all Lundsford titanium ball studs, screws and turnbuckles. My wallet's drained
RENOV8R is offline   Reply With Quote
Old 12-01-2015, 10:09 AM   #10205
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I run a 20 on a 7.5 so I would think a 22 should be a good starting point...........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-01-2015, 10:44 AM   #10206
rregl0612's Avatar
Trader Rating: 33 (100%+)
Front page says 26/27. I'm running a 7.5 and am starting first run today at 24.
What kind of heat are you getting on 20? I'm worried I might be too high. I was a nitro guy, so electric gearing I'd new to me. Any good links to understand reductions?
Hope I'm not hijacking dirt diggers post!
rregl0612 is offline   Reply With Quote
Old 12-01-2015, 10:47 AM   #10207
wittyname's Avatar
http://scriptasylum.com/rc_speed/car_setup.html
http://scriptasylum.com/rc_speed/gear_calc.html
http://scriptasylum.com/rc_speed/rollout_ratio.html
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 12-01-2015, 10:03 PM   #10208
nitro2be's Avatar
Originally Posted by nitro2be View Post
OUCH! After almost one year of driving like I stole it, I broke it bad. High speed jump on straight in air crash into the side of wall and it was LOUD.
well i finally got my car back together after my order had been lost for week. I used avid aluminum chassis with 27g in front and added 15g rear. Car looks good and is heavy,I'm liking it. with a 5.5 it should drive nice.
Are you guys adding weight to you mod cars? If so where and how much?
nitro2be is offline   Reply With Quote
Old 12-01-2015, 10:16 PM   #10209
nitro2be's Avatar
How were your Temps with the 24 pinion?
Old 12-01-2015, 11:46 PM   #10210
rregl0612's Avatar
Smoking!! Came off 160 after 3-4 minutes. Still figuring out the car so I wasn't full throttle for most of that.
Dropped to 22, and ran a pack to cut off, off the track at 155-160. (Normal hard driving) So I'm thinking 20/21 with a touch of timing will be tits!!!
Ps witty name thanks for the awesome links. They are saved!
Old 12-01-2015, 11:57 PM   #10211
nitro2be's Avatar
sounds like good deal. 21 +timing car be perfect .
Old 12-02-2015, 08:07 AM   #10212
hey guys will Losi or associated pistons fit these shocks ?
https://www.facebook.com/kyrcrc/
slowsrc is offline   Reply With Quote
Old 12-02-2015, 12:47 PM   #10213
Trader Rating: 40 (100%+)
The center hole on the Losi/AE pistons is larger than was is used for the D413.
Rick S is offline   Reply With Quote
Old 12-02-2015, 03:42 PM   #10214
Thank you
Old 12-02-2015, 06:03 PM   #10215
does anyone know what size drill bits i need to drill 1.6 and 1.7 pistons?
