Like Tree42Likes
Old 11-27-2015, 05:02 PM   #10186
RENOV8R's Avatar
Originally Posted by Jason84 View Post
Exotek also makes bushings to fix the slop.
Yes, they're just as good as the Xrays. The ones that come with the front hub carriers can also be used for the stock steering rack
RENOV8R is offline   Reply With Quote
Old 11-28-2015, 05:12 PM   #10187
Dose anybody know what brands make sway bars that are thicker than the stock black and still fit well? I noticed that Ronnefalk was running a much thicker silver one on the front at that worlds.
RacingCraze21 is offline   Reply With Quote
Old 11-28-2015, 05:17 PM   #10188
Trader Rating: 75 (100%+)
Default Help ! 10mm ball stud doesn't seem to exist
Need some help! Had a minor cartwheel today and broke the carbon fiber rear inner ballstud mount. Lesson learned, will stick with the stock metal piece. However, I bent the 10mm ball stud in the process. The part number is HBS112983, but it doesn't exist anywhere! Not on AMain, Tower, Stormer, Losi Parts House, AbsoluteHobbyz, eBay or even a Google search. I have no idea why that part doesn't seem to exist. Does anyone know where I can buy it, or perhaps another brand that will work? HPI lists the dimensions as 4.8x5x10mm. I use a 2mm washer under that ball stud so it needs to be the 10mm version. I can find the 8 mm version on AMain and Tower. It looks like AE makes a 10mm metric ball students for the TC3 cars, would that work?
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 11-28-2015, 07:06 PM   #10189
Maybe these will work...
https://www.teamassociated.com/parts/details/91049-ASC91049-heavy-duty_ballstuds_10mm/
16right is offline   Reply With Quote
Old 11-28-2015, 07:36 PM   #10190
Great question. Would love to know as well, also related it seems the entire setup (ball ends/cups etc.) looks much different than stock to accommodate the beefier sway bar.
http://www.neobuggy.net/2015/10/10/u...oto-ronnefalk/
Vincent_Diesel is offline   Reply With Quote
Old 11-28-2015, 07:39 PM   #10191
Originally Posted by RENOV8R View Post
Notice how much slop you have in your front wheels? Stock rack is the source of some of this. The Exotek rack will get rid of most of this. At the very least, you can replace the bushing in the stock rack with the Xray steering bushings. They're the same size but made to a much tighter tolerance
RENOV8R speaks the truth here. You want to minimize slop, try this.
Old 11-28-2015, 09:20 PM   #10192
STLNLST's Avatar
Trader Rating: 21 (100%+)
What brand of wheel do the spare hexes that come in the kit fit? I thought they were B44 but the hexes are too big. All the other HB drivers in my area seem to have run into the same problem. Anyone else have similar issues?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-29-2015, 09:15 AM   #10193
rregl0612's Avatar
Trader Rating: 33 (100%+)
Do these also fit the c hub, I have the exotech rack and now notice some movement here also. There's also some play in the dvd at the hub which I plan to shim out after break in tuesday
rregl0612 is offline   Reply With Quote
Old 11-29-2015, 11:51 AM   #10194
hello all i was hoping to get some advice on a motor for this buggy. do u think an 8.5 would be enough for a small technical indoor dirt track? thanks
DIRT DIGGER is offline   Reply With Quote
Old 11-29-2015, 12:32 PM   #10195
rcgod's Avatar
Trader Rating: 27 (100%+)
An 8.5 should be more than enough for a small track.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-29-2015, 12:33 PM   #10196
Actually looks a lot like either the D815 swaybar or an associated setup.
https://www.teamassociated.com/parts..._sway_bar_kit/
Jason84 is offline   Reply With Quote
Old 11-29-2015, 01:23 PM   #10197
MiQ
Does anyone know ballstuds with long threads? When I was driving with 4mm spacers in front links, inner stud ripped off from the gearbox. So I would need ballstuds with longer threads for more secure.(originals are 15mm?)
JQ BE - DESC410v2 - XB4 '16 - XB2 '17
MiQ is offline   Reply With Quote
Old 11-29-2015, 03:39 PM   #10198
anyone know the part number for the xray front hub carrier bushings? are these used in the d413 front hubs instead of the stock ones?
Old 11-29-2015, 05:13 PM   #10199
From RENOV8R a few pages back.
Exotek Part # 1535
Xray Part # XRA362290
Yes used on the front hubs and/or stock ackerman bar. I used 4 in total for D413 C-hub.
Old 11-29-2015, 05:15 PM   #10200
Yes I ordered 4 in total for the C-HUB. Minimized the slop greatly.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
davo798
