Like Tree31Likes
Old 11-24-2015, 12:36 PM   #10171
rregl0612's Avatar
Trader Rating: 33 (100%+)
Any off brand bodies available for this car? I've seen PL and JC make one, but not loving either, love the sweep of the factory but it's a pita to paint!!
Pl is definitely smoother and currently winning.
rregl0612 is offline   Reply With Quote
Old 11-25-2015, 06:01 AM   #10172
Bracer11's Avatar
Default New orange aluminum
Hey guys does anyone know where I can just get the aluminum parts for the buggy? I'd like a new set of orange. I'd prefer to not have to buy each seperate pack that includes seperate pieces.
Tekno EB48.4, NB48.4, ET48.3, EB410
Yokomo YZ2CA,
Bracer11 is offline   Reply With Quote
Old 11-25-2015, 07:19 AM   #10173
RENOV8R's Avatar
I'm assuming you're talking about the stock parts? Not that I'm aware of, pretty sure you'd have to purchase them all separately. Haven't done the math but it would be pretty spendy, might even be cheaper to buy a cheap roller off fleabay and strip'er down.
RENOV8R is offline   Reply With Quote
Old 11-26-2015, 05:19 PM   #10174
hello all im thinking about getting a d413 or a xray 2016. what u guys think of the car just wanted to get some thoughts on the car. thanks for info
DIRT DIGGER is offline   Reply With Quote
Old 11-26-2015, 05:30 PM   #10175
Fabulous's Avatar
Trader Rating: 42 (100%+)
I've had the B44.3, 22-4 and the Xray 2015. Currently running the D413. Cant speak for the 2016. But the D413 is the BEST in my opinion.
Fabulous is offline   Reply With Quote
Old 11-26-2015, 06:04 PM   #10176
Trader Rating: 25 (100%+)
Dirt digger I don't have any experience with the xray but have had a 44.3, 22-4 and as of yesterday purchased a D413. I haven't had a chance to run it yet but I will tell you this. The build is the best I've done yet, so easy and the fit and finish is awesome. I've raced with fabulous and know he's a die hard ae fan but for him to change to a D413 speaks very highly at least to me. There must be something with the buggy that he seen to make him switch.
toughtrax is offline   Reply With Quote
Old 11-26-2015, 06:12 PM   #10177
ok great thanks a ton for the responses! is there any aftermarket parts that i should get when i order the kit? thanks again
Old 11-26-2015, 06:31 PM   #10178
RENOV8R's Avatar
Exotek steering rack and spur gear, Avid bearings (my personal favorite but any quality bearings, the stock ones are crap) and Xray front hub carrier bushings. And HB aluminum shock caps. There's other stuff but it's mostly bling.
Old 11-26-2015, 06:38 PM   #10179
I can tell you what I ordered but all I could suggest from what I've read is that you would benefit from the aluminum shock caps. I will be posting more about what I find about the car in the next few weeks after I get mine up and running.
Thank You to Hobby Town Lake in the Hills/Timewarp raceway. Support your local hobby shops
AE B5M/HB D413
Old 11-26-2015, 06:43 PM   #10180
What is wrong with the stock steering rack?
AE B5M/HB D413
Old 11-26-2015, 07:21 PM   #10181
rcgod's Avatar
Trader Rating: 27 (100%+)
Something to be aware of with the HB alum shock caps they mount the shocks much closer to the tower than the stock caps and put the shocks at an angle which can bind up. Especially if you use a setup with forward arm sweep. I used longer screws and a couple of spacers to get the shocks back to the stock offset or close to it.
Hot Bodies D413 1/10 4WD Buggy-20151126_191949.jpg
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-27-2015, 07:21 AM   #10182
RENOV8R's Avatar
Notice how much slop you have in your front wheels? Stock rack is the source of some of this. The Exotek rack will get rid of most of this. At the very least, you can replace the bushing in the stock rack with the Xray steering bushings. They're the same size but made to a much tighter tolerance
Old 11-27-2015, 10:37 AM   #10183
Exotek also makes bushings to fix the slop.
Jason84 is online now   Reply With Quote
Old 11-27-2015, 01:02 PM   #10184
How much better is the exotek spur gear and will it spin true?
I've spent about an hour trying to get the stock spur gear to spin true with no luck.
16right is offline   Reply With Quote
Old 11-27-2015, 01:33 PM   #10185
The problem is you probably don't have the spur / diff cap on tight to the case. A lot of people are afraid to push it together really hard. Exotek one fits better as its aluminum and doesn't flex or bend. And if you overtighten one of the screws and bulge the plastic a little bit it will throw the spur off.
