Like Tree35Likes
Old 10-27-2015, 09:27 AM   #10051
jrz93's Avatar
Originally Posted by wittyname View Post
I have had this problem at my track , which is small and mostly 180's. I took the front bar off , and went with the smallest rear bar . Give it a shot
Thanks for help. I'm going to try 7/100/3 as your right when I went down in center to smooth out twitchy steering now back inside I had issue. Glad someone else experienced issue too on tight track
Also fyi avid rears stiffer than hb spring n help on power
jrz93 is offline   Reply With Quote
Old 10-28-2015, 03:28 AM   #10052
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to RC10B4_Mafco
Originally Posted by Vincent_Diesel View Post
My D413 was hooked up when our local track had low-medium grip indoor clay. We now switched over to astro and I am struggling with my setup. I am currently using Ty Tessmann 2015 IFMAR Astro setup:
http://www.tytessman.com/setups/pdf/...orlds-d413.pdf
Love to hear your thoughts about the carbon fiber chassis on high grip astro. With the CF chassis it just feels like it lacks control around the track. It feels very twitchy / sensitive. Overall it feels inconsistent especially around corners where it feels like grip is not linear. Both my RB6 and SC6 have aluminum chassis and they are very consistent and easy to drive -- but I love my D413 and would love to get some pointers.
Is stock CF chassis NOT the ideal choice for me, and would the AVID aluminum chassis be better for my medium sized high grip astro track? Is the price justified?
I also ran my D413 with the stock carbon chassis on astroturf, and the traction was very inconsistent and the car was very difficult to drive. With the amount of traction available, the carbon chassis will flex a lot, therefore explaining the car's handling characteristics. I am convinced that the AVID aluminium chassis will transform the car on astroturf. I have bought one, but I have not tried it yet. I think you should only be running an aluminium chassis in a 4wd buggy in high grip situations.
RC10B4_Mafco is offline   Reply With Quote
Old 10-28-2015, 07:19 AM   #10053
boudin4evr's Avatar
Trader Rating: 18 (100%+)
i need help
I read a long time ago about shock perches coming off in the front
fixes?
thanks
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 10-28-2015, 07:38 AM   #10054
Team Tekin
yzracer758's Avatar
New Parts from HB for higher traction/turf conditions-
12.5 and 15 Degree Caster Blocks: http://www.hpiracing.com/en/part/115751
+6 MM Carbon Chassis and extended top decks: http://www.hpiracing.com/en/part/115753
#6 Ackermann Arm Set: http://www.hpiracing.com/en/part/115756
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-28-2015, 07:46 AM   #10055
skrichter's Avatar
Send a message via AIM to skrichter
Originally Posted by Lexicus View Post
I converted the front of my car over. AE Ballstuds and HD Cups
https://goo.gl/photos/249ccXgCEKEWj97x6
Takes a little play out of the front.
Which Finnisher JC kit did you steal your turnbuckles from? Obviously they seem to be a great fit.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 10-28-2015, 10:16 AM   #10056
Maybe I'll wait for this as a solution for higher grip astro tracks. Any guess on when this will come to market? Or should I just get the Avid aluminum chassis in the meantime.
Vincent_Diesel is offline   Reply With Quote
Old 10-28-2015, 10:47 AM   #10057
Team Tekin
yzracer758's Avatar
These parts should be currently available as team drivers have had access to them for a month or so now...
Jeremy Potter
Tekin C.S. Manager
Old 10-28-2015, 12:08 PM   #10058
RENOV8R's Avatar
Originally Posted by boudin4evr View Post
i need help
fixes?
thanks
Drill a hole in them and ziptie them to the spring. Also keep the slot in them facing to the rear, they won't come off as often. Exotek makes an aluminum set that seem to stay on better
RENOV8R is offline   Reply With Quote
Old 10-28-2015, 02:01 PM   #10059
rcgod's Avatar
Trader Rating: 27 (100%+)
Any idea where? I can't find the caster blocks anywhere online.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-28-2015, 02:27 PM   #10060
4wd on Astro is a LOT more direct than indoor clay from what I have experienced. Regardless, I found the Avid chassis a lot more stable and predictable than kit, esp with the brass weight in the rear.
Diff oils tuned to suit, my preference is 10/300/7. Copper front roll bar, silver rear. Go to silver front if very grippy. If you mount the front shock tops on the inner hole, the steering response should be more predictable/docile. C/F wishbone inserts all round. Tyres on Astro also make a huge difference, what are you running?
I've just picked up the schelle +4 alloy chassis to run this weekend so we'll see how it behaves; currently pitches around a lot on high grip which can make for a challenging drive.
Btw, I race in the UK.
TobyStephenson is offline   Reply With Quote
Old 10-28-2015, 02:33 PM   #10061
Team Tekin
yzracer758's Avatar
I suggest contacting HPI directly and see what they say, they should know where they have been shipped.
Jeremy Potter
Tekin C.S. Manager
Old 10-28-2015, 04:42 PM   #10062
rcgod's Avatar
Will do thanks!
On another note, are most guys running glued plastic inserts in the arms on med bite clay or cf?
Dialed RC Hobbies
Old 10-28-2015, 06:20 PM   #10063
Greetings and thanks for the advice. I have a sneaking suspicion that you may know a thing or two about setting up for Astro : )
I am running Schumacher yellow mini pins on all fours. Please let me know about the schelle +4 alloy chassis. I may consider that as well. Also thank you for the tips above. Cheers!
Old 10-28-2015, 09:02 PM   #10064
Fabulous's Avatar
Trader Rating: 42 (100%+)
Hot Bodies D413 1/10 4WD Buggy-d413.jpg
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 10-29-2015, 12:16 AM   #10065
R1Joel's Avatar
^^ Very nice.
I just got a new body for mine:
R1Joel is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jmonte23
