Like Tree28Likes
Old 10-25-2015, 12:34 PM   #10036
nitro2be's Avatar
Originally Posted by Billy View Post
On what i think is called the spindle, you can place washers to raise by 1-2 mm. What are the effects of this? How does it affect the car. I currently have 2 washers under the spindle as in the 15 OCRC setup. Thanks in advance for the help.
+1. I wanna know too. I do know I like car best with 2mm under.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 10-25-2015, 03:17 PM   #10037
Trader Rating: 42 (100%+)
Don't know the technical details but higher spindles up front mean more steering to me. I run them high on this and my yz2.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 10-25-2015, 09:57 PM   #10038
Bracer11's Avatar
Can you use associated ball cups and ball studs on the D413?
Tekno EB48.4, ET48.3, SCT410.3
Yokomo YZ2, YZ4
Bracer11 is offline   Reply With Quote
Old 10-26-2015, 07:15 AM   #10039
Yes but if you are having issues with them popping off like I did first check to see if you have any ballcups especially the rear inners hitting the ballstud mounting plate like I did. I spaced the plate up 2mm and then put some droop and stuff limiters on mine.
I also switched to tlr 22 2.0 ballcups as they fit better on the stock HB ballstuds and I've not had one pop since changing.
Aaron Moore
Old 10-26-2015, 07:38 AM   #10040
Lexicus's Avatar
Trader Rating: 19 (100%+)
I converted the front of my car over. AE Ballstuds and HD Cups
https://goo.gl/photos/249ccXgCEKEWj97x6
Takes a little play out of the front.
Lexicus is offline   Reply With Quote
Old 10-26-2015, 09:40 AM   #10041
RENOV8R's Avatar
I'm using TLR ballstuds and cups. Also using the TLR 22 2.0 steering linkage which takes out a lot more slop. Just note that you need the TLR ballstuds with this as they're smaller than the HB 4.8 mm ones.
RENOV8R is offline   Reply With Quote
Old 10-26-2015, 03:16 PM   #10042
jrz93's Avatar
I run on a tight indoor track and car was pushing like a dump truck . I currently have the most agresive steering plates on knuckles and running 10/50k/5 in diffs and avid pink rear springs
I layed down front shocks .all else is Ty's setup
Car is awesome outside but on tight track won't turn
Please help
jrz93 is offline   Reply With Quote
Old 10-26-2015, 03:30 PM   #10043
nitro2be's Avatar
Please help
wow I can out turn everyone on track in tight corners, but if I'm getting push like dump truck I change tires and whala. My track we run slicks ,but after few runs and track drys I push and switch to broken in dirt weds . Are you changing tires for track conditions?
Old 10-26-2015, 06:54 PM   #10044
jrz93's Avatar
Experienced racer n everywhere in northeast we been running nothing but slicks for 2 years. Extremely high traction
Wondering if going back to higher center fluid will help cause I already have #3 Ackerman on knuckles
Old 10-26-2015, 10:05 PM   #10045
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Please help
Try 7/100/3 for the diffs. I'm not sure what the equivalent avid pink spring is to HB springs, but try yellow or gold HB spring (or equivalent on the rear). With the right tires, this buggy will turn with any of Ty's setups and you shouldn't have to go too far outside his setup sheets to get the car to work. I'll bet going from 50K to 100K in the center is going to make a big difference.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 10-27-2015, 04:40 AM   #10046
snwchris's Avatar
Plus on going to the 7/100/3... I run on Med to High bite and run 7/100/5 and car is super planted. I'm still running TYs original ready setup, other than springs. HB Red fronts with 40wt Losi oil and 2x1.6 pistons and for the Rear HB Gold with 30/32.5 wt Losi oil and 2x1.7 pistons.
It sounds like with the 10k front and 50k center might be part of issue. I ran 10/60/5 once and had some of the same issues with the push. When I went back to 7/100/5 turned on a dime.
snwchris is offline   Reply With Quote
Old 10-27-2015, 06:51 AM   #10047
wittyname's Avatar
Please help
I have had this problem at my track , which is small and mostly 180's. I took the front bar off , and went with the smallest rear bar . Give it a shot
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 10-27-2015, 07:48 AM   #10048
Vinny Cancilla's Avatar
Where are most the guys Mounting their esc, front or rear of the buggy. I've been running mine in the front and my car feels great. I'm going switch to the +4 schelle carbon chassis this week and was thinking about mounting it in the rear of the car. What are your thoughts. Has anyone treated both ways wuthering the same setup?
Vinny Cancilla is offline   Reply With Quote
Old 10-27-2015, 07:50 AM   #10049
Trader Rating: 130 (100%+)
I run my ESC up front with the +4 chassis. buggy feels great. plenty of steering all day with the chassis.
skyline1015 is offline   Reply With Quote
Old 10-27-2015, 07:56 AM   #10050
Default From Clay to Astro
My D413 was hooked up when our local track had low-medium grip indoor clay. We now switched over to astro and I am struggling with my setup. I am currently using Ty Tessmann 2015 IFMAR Astro setup:
http://www.tytessman.com/setups/pdf/...orlds-d413.pdf
Love to hear your thoughts about the carbon fiber chassis on high grip astro. With the CF chassis it just feels like it lacks control around the track. It feels very twitchy / sensitive. Overall it feels inconsistent especially around corners where it feels like grip is not linear. Both my RB6 and SC6 have aluminum chassis and they are very consistent and easy to drive -- but I love my D413 and would love to get some pointers.
Is stock CF chassis NOT the ideal choice for me, and would the AVID aluminum chassis be better for my medium sized high grip astro track? Is the price justified?
Vincent_Diesel is offline   Reply With Quote
