Like Tree31Likes
Old 10-09-2015, 04:59 AM   #9946
RENOV8R's Avatar
Originally Posted by Brandonmorris44 View Post
Which servo horn are y'all running? I need a 24t for my 7955tg but I want to get a aluminum one.
I'm using a TLR horn, but the HPI horn is good too.
RENOV8R is offline   Reply With Quote
Old 10-09-2015, 09:06 AM   #9947
RENOV8R's Avatar
The swaybar ends come out of the holders every time I drive. Anybody have an easy fix? I was thinking of dremeling a notch in the end of the swaybar, but they're pretty small diameter
Old 10-09-2015, 09:11 AM   #9948
Brandonmorris44's Avatar
Trader Rating: 33 (100%+)
I read on here where a guy flattened the ends like your talking about to allow the set screw to face up better on sway bar and he also used a little ca glue dropped in the hole then set the screw.
Brandonmorris44 is offline   Reply With Quote
Old 10-09-2015, 09:13 AM   #9949
snwchris's Avatar
I don't run a front swaybar but the rear swaybar has been fine the whole year.
snwchris is offline   Reply With Quote
Old 10-09-2015, 09:15 AM   #9950
When installing the swaybars, I put the 3x3 set screws in the shock tower and the 3x4 screws in the swaybar ends so they don't strip so easily. Never lost a swaybar end in a year and a half. If the ends are already stripped, replace them or you could try a bit of ca glue too.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 10-09-2015, 11:23 AM   #9951
nitro2be's Avatar
Originally Posted by nrm1977 View Post
Thanks Rick! Last question for anyone, I have both the B and C rear shock tower. I don't remember which one is the B tower and which is the C, how can I tell them a part?
Thanks in advance!
The c should be wider. I have both but have not look in a long time. Best of my memory.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 10-09-2015, 12:05 PM   #9952
Thanks in advance!
Shock mounting holes are lower in the C tower.
Sofa King Racing
Old 10-10-2015, 03:19 AM   #9953
I have been running ty's carpet setup with PL pin point tires and i cant get the feel for it.. anyone that has a better setup ? i run with schelle alu chassis.
Also witch shock towers are you using? It seems most logic to me to use A on carpet?
boggiii is offline   Reply With Quote
Old 10-10-2015, 09:45 AM   #9954
Trader Rating: 137 (100%+)
Running basically kit, with a few tweaks from Ty's Reedy Race setup for indoor high bite clay on slicks. Problem that I am having is when it lands off of a jump the rear end gets squirrelly no matter how perfect I downside the jumps, it weirds out. How can I smooth that out a bit? Not really interested in buying new parts to make this happen, I'd like to keep the car as stock HB as possible.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-10-2015, 04:53 PM   #9955
Try the "C" rear tower... you will have to buy a part...
Sofa King Racing
Old 10-11-2015, 01:57 PM   #9956
Billy's Avatar
On these pictures of Ty's 4wd is the fan located behind the motor bell blowing air into the bell or pulling air away from the motor which goes with air flow of the car? I can't really see the pitch of the fan blades.
http://events.redrc.net/2015/10/chas...y-tessmann-11/
Billy is offline   Reply With Quote
Old 10-11-2015, 03:01 PM   #9957
Anyone have any other ideas here? HBS112763 Hot Bodies Rear Shock Tower (C-Use w/Gullwing) D413.
What is the "Gullwing". Found it.
Old 10-11-2015, 03:23 PM   #9958
I'm looking for spring rates in lbs for the 413 anyone?
turtle189 is offline   Reply With Quote
Old 10-11-2015, 04:15 PM   #9959
Trader Rating: 44 (100%+)
I always thought you push the air into the component you want to cool. I haven't found a little fan that can pull hot air away fast enough to be effective.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 10-12-2015, 03:51 AM   #9960
cokemaster's Avatar
Trader Rating: 18 (100%+)
I have converted the spring rates in the attachement.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
