Like Tree28Likes
Old 10-08-2015, 08:51 AM   #9931
Default D413 max motor length w/ saddles
I was thinking of getting the d413. I would be using saddles and the foreword motor mount position looks tight. The motor I would be using is 58 mm long so it's slightly longer than a standard 540 can. Does anyone know if it would fit? Thanks in advance!
Manchild is offline   Reply With Quote
Old 10-08-2015, 09:43 AM   #9932
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Will not fit, you will need a motor under 50mm in length to run saddles.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-08-2015, 10:36 AM   #9933
Brandonmorris44's Avatar
Trader Rating: 33 (100%+)
I'm building my kit for saddles I ordered the smc packs because it had good luck with smc in the past and they are very well priced. I plan to set the car up with 10k/100k/7k for my high bite indoor clay tight track. I will be running a LRP 6.5t motor what gearing would y'all recommend with that configuration? And would the 1.6 or 1.7x2 pistons be better for that track? I plan to install yellow springs on rear and gold on front any suggestions on oils?
Brandonmorris44 is offline   Reply With Quote
Old 10-08-2015, 10:49 AM   #9934
Gertsch's Avatar
new parts...
http://events.redrc.net/2015/10/chas...y-tessmann-11/
#runmod
Gertsch is offline   Reply With Quote
Old 10-08-2015, 10:50 AM   #9935
Thank you sir!
Old 10-08-2015, 11:54 AM   #9936
Trader Rating: 137 (100%+)
Originally Posted by Gertsch View Post
I'm gonna be all over that slipper when it comes out, I hate center diffs.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-08-2015, 02:36 PM   #9937
RENOV8R's Avatar
Yes, the SMC's are a great value, but I don't really know anyone running saddle packs. It's just a better driving wheeler with shorty setup. With a 6.5 I'd say start at 23T and see how that works for ya. Diff fluid is pretty good, but you might end up dropping to 80K. 1.6 2 hole front and 1.7 rear is a pretty popular setup. Spring selection is the same as I'm using and works great for me.
RENOV8R is offline   Reply With Quote
Old 10-08-2015, 02:42 PM   #9938
Trader Rating: 22 (100%+)
Just take my money now
noproblems209 is online now   Reply With Quote
Old 10-08-2015, 03:51 PM   #9939
Thanks for the help man and I have no idea why I said I'm building mine for saddles I meant to say shortys I just ordered 2 shorty packs from smc I ran saddles in my 44.2 and .3 I got sickofmessibg with the saddles.
Old 10-08-2015, 03:52 PM   #9940
Which servo horn are y'all running? I need a 24t for my 7955tg but I want to get a aluminum one.
Old 10-08-2015, 06:36 PM   #9941
Trader Rating: 65 (100%+)
I'm curious if anyone is running the esc behind the motor instead of infront?
nrm1977 is offline   Reply With Quote
Old 10-08-2015, 06:47 PM   #9942
Trader Rating: 40 (100%+)
On my son's car we have the ESC in back with the receiver and transponder in front. The car is balanced well and the wires to the motor are much shorter.
Rick S is offline   Reply With Quote
Old 10-08-2015, 08:03 PM   #9943
Thanks Rick! Last question for anyone, I have both the B and C rear shock tower. I don't remember which one is the B tower and which is the C, how can I tell them a part?
Thanks in advance!
Old 10-08-2015, 09:42 PM   #9944
STLNLST's Avatar
Trader Rating: 19 (100%+)
I'm currently setting my electronics up this way with the stock chassis. I hit the ground with this car running the Schelle +4 aluminum chassis with the electronics in the front.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-09-2015, 04:11 AM   #9945
snwchris's Avatar
When I had the stock chassis and now with the Schelle Carbon chassis I run my ESC behind the motor and the RX & TP in front of the motor. When I put the car on scales at all 4 corners it was balanced real nice.
snwchris is offline   Reply With Quote
