Like Tree29Likes
Old 09-29-2015, 06:20 PM   #9916
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Originally Posted by RENOV8R View Post
I use Losi 22-4 wheels, but there's nothing wrong with the stock ones
So rear JConcepts 22/B5 wheels work then? The 22-4 fronts are a tad cheaper as well
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 09-29-2015, 06:20 PM   #9917
savageboy69's Avatar
Trader Rating: 88 (100%+)
Originally Posted by wittyname View Post
I have a question .... I am going 5.5t and I am wondering if thinner center diff fluid leads to higher temps at the motor ? I can see it in my mind doing that , but I am really not that smart . I have 50k in my center diff now , and I like the way the car drives.
Anyone test this ? It seems like the sort of thing someone has looked into
I ran a 5.5 with 60k center all last year and motor was around 160 ish with 21t pinion
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is online now   Reply With Quote
Old 09-30-2015, 09:14 AM   #9918
rr 22/b5 wheels work
TPJ International
071crazy is offline   Reply With Quote
Old 10-03-2015, 10:56 PM   #9919
anyone have a good set up for a high bite clay track
my63wagon is offline   Reply With Quote
Old 10-04-2015, 04:45 PM   #9920
RENOV8R's Avatar
Ty Tessman has the setup you're looking for on his website
RENOV8R is offline   Reply With Quote
Old 10-04-2015, 04:57 PM   #9921
RENOV8R's Avatar
So, I've done lots of experimenting with the "slop", even though I'm still not sure it really matters. As far as the steering rack goes I've done lots of fiddling with the RCShox and Exotek units but by far the best setup I've found is the stock rack with the Exotek bushings (Part #1535) Very smooth and zero slop. Just sayin......
Old 10-04-2015, 11:05 PM   #9922
thanks for info
Old 10-05-2015, 01:28 PM   #9923
Motorman007's Avatar
Trader Rating: 76 (100%+)
What is a good starting point for tekin 8.5t?
What is the drive ratio of this buggy.
For a small bullring type track?
Thank you
Found it
Motor 4wd FDR D413 pinion
4.5 12 19.8
5.5 11 21.7
6.5 10 23.8
7.5 9.5 25.1
8.5 9 26.5
10.5 8 29.8
13.5 7 34.0
17.5 6 39.7
YOU WILL (ALWAYSWIN).....
Last edited by Motorman007; 10-05-2015 at 01:32 PM. Reason: Motor 4wd FDR D413 pinion 4.5 12 19.8 5.5 11 21.7 6.5 10 23.8 7.5 9.5 25.1 8.5 9 26.5 10.5 8 29.8 13.5 7 34.0 17.5 6 39.7
Motorman007 is offline   Reply With Quote
Old 10-06-2015, 06:22 AM   #9924
Brandonmorris44's Avatar
Trader Rating: 33 (100%+)
Are wheel nuts on this car 4mm?
Brandonmorris44 is offline   Reply With Quote
Old 10-06-2015, 09:03 AM   #9925
Gertsch's Avatar
yes
#runmod
Gertsch is offline   Reply With Quote
Old 10-06-2015, 02:45 PM   #9926
Hi ,, anyone know if there's a new d413 kit comming out for the 2016 season.
BRIAN77 is offline   Reply With Quote
Old 10-06-2015, 03:10 PM   #9927
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
I wouldn't think so as the current kit works well in a multitude of conditions. There are some new parts coming out however to help with high grip tracks.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 10-07-2015, 01:40 PM   #9928
Hey guys I just dumped my 44.3 for this car I ordered the kit from Amain yesterday along with several different sets of springs some extra arms shock towers diff cases ball cups just normal extras purchased the exo tech chassis brace and steering plate. Could y'all tell me what brand and weight diff oils shock oils I should order to have on hand for building kit along with which Pistons 3 hole 1.6 etc? I run on high bite tight indoor track mostly hut occasionally run outdoor very loose low traction as well. I know I've read to have some 100k,60k,300k on hand depending on track conditions for center diff are y'all running mugen,Losi,ae oils which one?
Old 10-07-2015, 02:09 PM   #9929
Team Tekin
yzracer758's Avatar
Shock Pistons: 2x1.6 and 2x1.7mm
TLR Shock Oil: 30-42.5 Range
AE Diff Oil: 2k, 3k, 5k,10k, 15k, 60k,80k, 100k
Jeremy Potter
Tekin C.S. Manager
Old 10-07-2015, 03:46 PM   #9930
Thanks Jeremy
