Like Tree35Likes
Old 09-22-2015, 06:29 PM   #9886
Trader Rating: 75 (100%+)
Default Lunsford Titanium Turnbuckles
I see quite a few of you replaced the stock turnbuckles with the Lunsford titanium turnbuckles. Are the stock turnbuckles prone to bending and/or breaking? In other words, are the Lundsford titanium turnbuckles a required upgrade? Do the stock ball cups fit on the Lunsford titanium turnbuckles, or would you need to buy the lundsford ball cups as well?
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 09-22-2015, 08:08 PM   #9887
What is a good setup for the OCRC track( indoor hard pack clay, medium to high bite). I like the buggy but it seems to step out in the back and get squirely in the rear when I get on the throttle some corners?
My current setup is:
Front: 37.5 wt, Gold springs, 1.6 pistons, Diff 10K, no swaybar
Rear: 32 wt, Yellow springs, 1.6 pistons, Diff 5K, Black swaybar
Center 100K diff, 7.5 Tekin motor
Dirt webs gold all around.
I am using Tys 2014 Reedy setup
AJrollin is offline   Reply With Quote
Old 09-22-2015, 08:38 PM   #9888
Trader Rating: 65 (100%+)
Im having the same issue with my rear end of the buggy breaking loose on power. Trying to figure out how to lock the rear end in....suggestions?
10k 100k 10k diffs
42.5f and 35r with 1.6, 1.7 vrp pistons, kyo orange front and kyosho white/red rear
I went stiffer swaybars from kit....black/silver i believe
Everything else is box setup
nrm1977 is offline   Reply With Quote
Old 09-22-2015, 09:30 PM   #9889
I didnt have any problem with my stock turnbuckles other then they looked cheap and toy like. I went with the lunsfords because i had a stock pile left over from my dirt oval cars. They fit my stock ball cups perfectly.
Apexracing is offline   Reply With Quote
Old 09-23-2015, 04:01 AM   #9890
snwchris's Avatar
10k 100k 10k diffs
I've been running TYs original Reedy Setup for past 1yr now and feel pretty planted even with the stock chassis. I run on Med to High Bite and also have the Schelle Carbon chassis and 7.5 motor.
For Diffs I run 7-100-5, no swaybar in front and black swaybar for rear.
Front Shocks: 2x1.6 HB Red 40wt Losi and Traxxas Xrings
Rear Shocks: 2x1.7 HB Gold 30/32.5 wt Losi and Traxxas Xrings
I can drive the car pretty hard in and out of the turns and so far never had an issue with it stepping out or breaking loose.
Also with my stock & Schelle chassis I switched the layout of stuff. ESC behind the motor, RX & TP front of motor
snwchris is offline   Reply With Quote
Old 09-23-2015, 05:36 AM   #9891
Trader Rating: 15 (100%+)
10k 100k 10k diffs
1. Lower rear diff, go to 3-5k
2. Copper sway bars front and rear
3. Increase front droop, decrease rear
4. Use the kyosho springs ty typically runs
uncle everett is offline   Reply With Quote
Old 09-23-2015, 08:45 AM   #9892
wittyname's Avatar
Play with those diffs ....
The 10/100/10 IMO is really geared towards high bite tracks.
I am down to 7/50/3 in my car and love the way its driving. If you think about how adjustable a ball diff is , and compare that to the difference between using 3k or 5k or 7k diff fluid in a gear diff you can start to get an idea of how dramatic the diff oil changes really are.
Try as many as you can find the time to try . I am pretty confident that I could tighten a ball diff as tight as it can get , and not come close to the effect 10k weight oil would have. If you wouldn't run really tight ball diffs at your track , than the 10k is probably too much.
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 09-23-2015, 09:55 AM   #9893
+ 1,000,000
When I upgraded from my 13 XB4 to my 14 XB4 I couldn't believe how terrible the 14 felt compared to my 13. The car was super twitchy, had way too much steering and drove so hard from the front wheels that the rear of the car just got slung around on power. It seemed like it wasn't making rear traction. I set the slipper setting exactly as specified by the XRay manual. I saw other guys at my track with B44.3s who were having similar problems and they went to 60K in their center diffs and their problem went away. So I began to loosen the slipper on my XRay and the car just kept getting better the more I loosened it. I had loosened it almost .75mm more than the manual suggested and it made a huge difference. The car was glued to the track. And this was on a high traction track where we run slicks. Normally the slipper/diff is set-up tighter/higher for high traction tracks, but we all preferred a looser center slipper/diff.
XRAY 17 XB4
Yokomo YZ-2 CA
Old 09-24-2015, 10:50 AM   #9894
Trader Rating: 44 (100%+)
Default Dogbone Pin replacement
Hey Guys,
I asked about this a while back but didn't get a response. Anyhow I was able to replace my dog bone pins and found that the serpent 2.5mm x 10mm fit pretty good. They are a bit shorter than the stock ones by about .5-.75mm but do not seem to be an issue with engaging in the drive cups. Anyways, I'm looking for a better solution and am going to try some 2.5 x 11.8mm pins to see if they will work better. I'll report back when I find the optimal solution. Just thought I'd share in case anyone was interested in replacing their own pins instead of having to buy the entire drive shafts.
Hot Bodies D413 1/10 4WD Buggy-serpent-2.5-x-10-pins.jpg
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 09-24-2015, 01:50 PM   #9895
Here's a question for anyone to respond too... Recently I built my D413. I have about 6 runs on the car. I pulled out the front and center Diffs to change the oil for tuning. And the oil was really dirty. I guess my question is... Is that normal being the first oil change? And how often should I change/ freshen up the oils in the diffs?
RacingCraze21 is offline   Reply With Quote
Old 09-24-2015, 02:34 PM   #9896
Originally Posted by Antimullet View Post
Hey Guys,
What tool did you use to change the pins?
moch8 is offline   Reply With Quote
Old 09-24-2015, 05:27 PM   #9897
I used my shop vice, a small socket, and another pin that was smaller in diameter. Take some vice grips, grab the smaller pin in the middle. Then take the dogbone, place it against a small socket like a 6mm socket so that when you stick that in the vice the pin can push out into the socket.
Push the pin halfway through till it bottoms out in the vice, open the vice, hold the socket, dogbone, and grab the vice grips with the small pin in it and line that up with the dogbone, all that goes in the vice and use that small pin to press the dogbone pin out the rest of the way until it falls into the socket.
There's a video online I think changing kyosho dogbone pins. A visual explains it much better.
I'm cheap, but if these pins don't last long I'll invest in a proper tool.
Aaron Moore
Old 09-25-2015, 12:52 AM   #9898
What body options is out there for this car? JC, proline and stock. .anything else?
boggiii is offline   Reply With Quote
Old 09-25-2015, 03:54 AM   #9899
snwchris's Avatar
^^^ Those are basically the only ones currently available
Old 09-25-2015, 05:16 AM   #9900
RENOV8R's Avatar
When someone talks about adjusting droop, Im assuming that this can only be done by lengthening/shortening the shock ends?
RENOV8R is offline   Reply With Quote
