Like Tree42Likes
Old 09-11-2015, 06:33 AM   #9841
RENOV8R's Avatar
Originally Posted by jhautz View Post
Yea. Maybe I described it poorly. In the short steering linkage there really isn't any binding. Just a tight enough fit that the ball studs don't move around in the freely. They don't flop around under their own weight any more and it tightens it all up.
I'm sure there are studd/cups that work as well like you are saying.
Makes sense, I just looked and the Xrays are 4.9 mm whereas HB is 4.8 mm.
RENOV8R is offline   Reply With Quote
Old 09-11-2015, 06:37 AM   #9842
RENOV8R's Avatar
Originally Posted by jgonz View Post
What brand of machined pistons work best in the d413
The RCShox pistons are OK, but the VRP X pistons are so much better IMO. Smoother action and quicker rebound
Old 09-11-2015, 09:46 AM   #9843
RENOV8R's Avatar
Originally Posted by snwchris View Post
There's a few of us at our track using the B5/B5M Ball Studs (8mm) and Ball cups and remove the slop and still plenty of free movement, no binding issues.
The TLR balls & cups also work well
Old 09-11-2015, 06:07 PM   #9844
Trader Rating: 54 (100%+)
Going to instal the VRP 1.6 and 1.7 Pistons. What associated shock oil should I start with?
Speedychris22 is offline   Reply With Quote
Old 09-11-2015, 08:47 PM   #9845
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
40 front 35 rear, possibly drop 2.5 weight as an alternate.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 09-12-2015, 05:17 PM   #9846
Thanks will give that a shot
Old 09-14-2015, 02:05 AM   #9847
R1Joel's Avatar
First race with my D413 on the weekend. Took out all three qualifiers and the final. Box stock. Such a joy to drive.
R1Joel is offline   Reply With Quote
Old 09-14-2015, 07:52 AM   #9848
wittyname's Avatar
Good Lord this thing is fun.... Went through the car and made some changes to better suit my track . I have the car sprung soft (2 steps softer than stock) , 7/50/3 with 32 f and 30 rear , front bar , 21mm ride height , and 11deg front and its is just a pleasure. Even more impressed than I was before. Car is tough and responds well to changes . Its fast .... I still cant believe how someone as untalented as myself can push this thing and not have to pick up the pieces. Running indoors wed night coming up and looking forward to it.
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 09-15-2015, 05:52 AM   #9849
RENOV8R's Avatar
What type of track are you running on with this setup?
Old 09-15-2015, 07:27 AM   #9850
RENOV8R's Avatar
Instead of using ugly cut out bladders, wondering if anybody knows what o-rings will fit in the shock caps?
Old 09-15-2015, 07:36 AM   #9851
SeanKewley's Avatar
A good trick for cutting bladders is to use a brass tube from your local hobby shop, sharpen one end... I use a step drill bit to sharpen it, and then set the bladder on a piece of wood with the tube where you want the hole and give it a tap with a hammer.
SeanKewley is offline   Reply With Quote
Old 09-15-2015, 10:22 AM   #9852
wittyname's Avatar
1/8 scale outdoor track . 120 ft straight , hard clay , light sandy dusty top layer . small doubles .
1/10 indoor track , maybe 40 foot straight , hard clay , no grip small jumps as well.
Josh W.
Old 09-16-2015, 08:59 AM   #9853
made a few changes on my d413, went to black sway bars front and rear and 35 weight shock oil. Going from a boosted 10.5 to 7.5 motor. Really considering a extended chassis for next season......
Apexracing is offline   Reply With Quote
Old 09-16-2015, 09:01 AM   #9854
Trader Rating: 133 (100%+)
i found the extended chassis made the buggy a little more easier to drive. i drove mine back to back with the stock chassis and schelle. my times are much better with the schelle
skyline1015 is offline   Reply With Quote
Old 09-16-2015, 09:05 AM   #9855
I found the thicker shock oil helped allot. Its a 1/8 sized track thats 1/10 friendly. I'm looking forward to trying out the thicker sway bars this weekend. My buggy is very planted, i'm just looking for more control through the air and some better handling through bumps (although its already the smoothest buggy in the whoops section of our track) I know i can make up more time, and the motor will help allot. Just thinking the chassis will make it more enjoyable to race.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
