Like Tree28Likes
Old 08-19-2015, 09:06 AM   #9721
Suspended
Originally Posted by nrm1977 View Post
Question- Curious to know what other brand rims match up with the d413's (losi, AE). Thanks
Take about 10 minutes to read the first post (and I mean really actually ready it, not just skim over it). The answer to this question and your question about the Traxxas x-rings are both in post #1.
The D413 is a great car, even for guys that sell stuff 3 minutes after they get it.
Mantis Toboggan is offline   Reply With Quote
Old 08-19-2015, 10:28 AM   #9722
Gertsch's Avatar
Originally Posted by Antimullet View Post
Nope this one....
You can use that one xtra stiff, or the next one down stiff in terms of servo saver give.
Thanks a lot for the Feedback!
cheers!
Gertsch is offline   Reply With Quote
Old 08-19-2015, 08:50 PM   #9723
Originally Posted by Dan.J View Post
I run Avid's as well, cheap and seem to hold up well.
http://www.avidrc.com/flexkit/?kit=842&kitname=D413
Thanks, i will try them
Egress is offline   Reply With Quote
Old 08-20-2015, 04:50 AM   #9724
RENOV8R's Avatar
I use Losi 22-4 rims front and back
RENOV8R is offline   Reply With Quote
Old 08-20-2015, 08:13 AM   #9725
Timrod's Avatar
Trader Rating: 47 (100%+)
Hey guys, I'm having a problem with the left front of my car. When I tighten the nut down on the wheel, the when you turn the wheel it's pretty tight. It doesnt have that slight motion of the front to back like on the other side, and other d413's at my track. Its also making a clicking sound when I turn the wheel sometimes. It's not the rim cause I took all the supports off thinking it was but it still does it, and with other rims it does the same thing. The bearings were replaced as well. When I come off the track the nut is much looser then when I put it on. I thought it might be the hub so I changed it and I replaced the crush tube. It worked for a while but now it's back to the same old thing. The other side has never done it. I also looked at the cvd's and axle when it was apart and had some other people look at it and they thought it was fine. Any ideas though?
Tekno eb48.3
Sponsors:
B-fast diffs ~ ARCS Raceway ~ Protchko R/C Painting
Timrod is offline   Reply With Quote
Old 08-20-2015, 08:26 AM   #9726
Trader Rating: 15 (100%+)
Is your spindle in the middle?
Does the orange universal cover have a wear line on it?
uncle everett is offline   Reply With Quote
Old 08-20-2015, 08:30 AM   #9727
Suspended
Timrod,
Try swapping the axle/driveshaft from the other side to see if the problem changes sides.
I would also pull the steering spindle off the troubled side, then build everything up with the spindle off the car. That way you can get a better look at everything.
Sounds like the spindle might be cracked, and when you tighten down the wheel its able to crush the bearings together some. Or maybe your wheel hex is bent ever so slightly.
Let us know what you find.
Old 08-20-2015, 09:17 AM   #9728
snwchris's Avatar
When you hold the car in your hand and blip the throttle, does it do it so you can hear or feel the issue... or notice the wheel wobble like maybe a slightly bent axle stub.
snwchris is offline   Reply With Quote
Old 08-20-2015, 09:24 AM   #9729
Timrod's Avatar
I'll take a look at it. I'm going to the mugen challenge this weekend so I'll work on it afterwards and let you know what i find out. I've changed the hexes and that wasn't the issue so that's out. Thanks for the imput
Tekno eb48.3
Sponsors:
Old 08-20-2015, 09:28 AM   #9730
Timrod's Avatar
Spindle is in the middle and there is not even a scratch on the orange cover. It's all free till I'm about 3/8 to 1/2 a turn from tightening the wheel fully for the race. I don't crank down on the thing either, just nice and tight like everyone else and like I've always done. I'll check it out though and let you guys know
Tekno eb48.3
Sponsors:
Old 08-20-2015, 10:20 AM   #9731
nitro2be's Avatar
Talking
I know exactly what it is. I had same thing. Back the 3x20 rear front left screw off a 1/4 turn that hold hinge pin in front. Front diff case worn and needs to be replaced. I just leave mine snug and check it every couple runs for coming loose.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 08-20-2015, 12:39 PM   #9732
Timrod's Avatar
Thanks a bunch. I'll try that and hopefully it works. I woulda never thought of that and it still sounds weird but I'll definitely give it a shot.
Tekno eb48.3
Sponsors:
Old 08-20-2015, 01:32 PM   #9733
Trader Rating: 42 (100%+)
Exotek released some new parts. Just ordered them off their website.
New spindle bushings for tighter tolerances
New front hexes that lock the pins in place
They also have some nice new aluminum hubs.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 08-20-2015, 09:36 PM   #9734
Cool stuff! Only thing missing is now nice aluminium rear hubs. Not that they are necessary, i never broke a hub on my car, would just be cool to have to match the front hubs!
Old 08-21-2015, 05:28 AM   #9735
RENOV8R's Avatar
Thanks! Just ordered the hubs and bushings. I've been using the X-Ray bushings, we'll see if these are as good
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
