Like Tree42Likes
Old 08-02-2015, 09:15 AM   #9616
The upgrade did take the slop out but the ball cups were tight a popped off easily if I even tapped anything until they broke in. Probably should use the Xray cups also. Has anyone used the Xray cups? Part #. Thanks
http://www.rctech.net/forum/attachme...1&d=1438543883
Hot Bodies D413 1/10 4WD Buggy-untitled413.jpg
bladeys is offline   Reply With Quote
Old 08-02-2015, 01:23 PM   #9617
Originally Posted by bladeys View Post
Thank you for sharing this upgrade it is remarkable.
Old 08-02-2015, 07:58 PM   #9618
kenny lutz's Avatar
Trader Rating: 36 (100%+)
My car seems to want to wheelie when you get on power has anyone else had this issue or found a fix for it? I'm running 7/100/3 then tried 10/80/5 with same result
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 08-02-2015, 08:05 PM   #9619
My car does this on occasion, i switched the wing to the low position and it seems to help. But i also thought of moving the receiver up front.
Apexracing is offline   Reply With Quote
Old 08-02-2015, 08:13 PM   #9620
Suspended
Does it wheelie over? I run slicks on a high grip clay track and mine will wheelie a little, but the center diff prevents it from wheelying over. I run 100k in my center diff too. Maybe try to be a little less aggressive on the trigger. If your car doesn't wheelie over is it really that much of a problem?
Mantis Toboggan is offline   Reply With Quote
Old 08-02-2015, 08:15 PM   #9621
My has a few times on landing ramps after a jump. Medium bite to loose traction clay out door track. Running J concepts flip outs.
Old 08-02-2015, 08:16 PM   #9622
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Care to say what track it is that you race at?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-03-2015, 12:26 AM   #9623
You could also try increasing the antisquat.
moch8 is offline   Reply With Quote
Old 08-03-2015, 02:19 AM   #9624
Gertsch's Avatar
Same question here, im working on the slop andīll order the xray ball ends, but have no idea how itīll work with the xray cups vs. HB Cups.
Part# would be awesome, thx!
Gertsch is offline   Reply With Quote
Old 08-03-2015, 05:25 AM   #9625
snwchris's Avatar
A lot of the 413 owners at our track use the B5M Ball Cups and Ball studs and have been working great. Plus there's a lot more LHS that carry AE B5 items too, so they are easier to find.
snwchris is offline   Reply With Quote
Old 08-03-2015, 07:05 AM   #9626
What are they using for the rear hub carrier? I've snapped a couple outer camber link ends(the captured one, my fault) but would to switch to a more readily available style. I like the B5 option.
CaseyD is offline   Reply With Quote
Old 08-03-2015, 07:47 AM   #9627
snwchris's Avatar
Still using the stock HB Rear hub and rear link and HB ball cups. With the hub mounting point being smaller I haven't found one to fit or work yet.
The B5M Ball Cup and Studs were mainly to get rid of the slop up front in the steering.
Old 08-03-2015, 08:38 AM   #9628
kenny lutz's Avatar
It will stand completely up if i don't let off the throttle to keep it from happening. it does create a issue because there is a couple places where you need to be on the gas hard and I'm not able to do that because it will wheelie and i have no control over the front to set up for the corner.i went to 80 center and it made it a little better but the car drives horrible so im going back to the 7/100/3
Old 08-03-2015, 08:39 AM   #9629
Gotcha. Not saying they are necessary by any means but I'm surprised exotek or Revolution hasn't made an aluminum hub carrier with maybe a TLR style top with multiple ballstud locations. However it is nice not popping a ballcup if you land a little sideways off of a jump.
Old 08-03-2015, 10:20 AM   #9630
Gertsch's Avatar
Ok, thanks for the info!
cheers
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
dieselstation, SouthFloridaApp
