Like Tree28Likes
Old 07-01-2015, 03:12 PM   #9496
Dal
Dal's Avatar
Send a message via Yahoo to Dal
Another dumb one here, how is the wing able to mount in a high and low position?
I cant see any different mount positions, or do I need a different mount?
Originally Posted by T. Deguzman View Post
it's a built in feature - you can run the mounts in a high or low wing configuration. high wing is more stable on the ground. low wing is more stable in the air during high wind conditions. it was very windy at the worlds coupled with some big jumps.
Dal is offline   Reply With Quote
Old 07-01-2015, 03:21 PM   #9497
Wing mounts rightside up (high) or upside down (low).
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 07-01-2015, 03:29 PM   #9498
Dal
Dal's Avatar
just googled images, wow, thats crazy low, thanks
Old 07-02-2015, 12:11 AM   #9499
nitro2be's Avatar
It is crazy, I've tried it for 2 minutes and went back to normal. I ran at local out door track tonight for 1st time since my indoor track closed, this buggy kicks a$$. Only change was to stiffer springs and the car was glued. Took a head on colision with a SC on the straight and thought for sure I'd be done, but kept going ,Nothing wrong, and heard the SC guy say "I'm broke". Lol. He crossed over not me. I'm in love with hot bodies d413
nitro2be is offline   Reply With Quote
Old 07-03-2015, 12:57 PM   #9500
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Default Dreaded front shock shaft...
Hello All, looks like I've succumb to the dreaded front shock shaft problem. Took a head on collision when someone jumped the track and snapped it just above the shock end. And to make matters worse it doesn't seem like anyone has them in stock. Anyone want to sell me one? Or if you can point to a known source of them in stock. I've placed a few orders so far only to be told the website was wrong or that it will be a few weeks. Thanks!
13Maschine is offline   Reply With Quote
Old 07-06-2015, 09:33 AM   #9501
13Maschine's Avatar
Has anyone tried using the Pro Line Pro Shock shafts up front? according to their site it seems to work with 5mm of limiters.
http://www.prolineracing.com/perform...kit-1-10-rear/
"Use 6267-01 in the Front with 5mm of limiters and use 6308-01 or 6308-31 in the Rear. Use 2mm spacers on the top of the shocks to get the correct shock angle."
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
Old 07-06-2015, 09:44 AM   #9502
snwchris's Avatar
I don't think those PL shock shafts fit in the HB shock bodies. I think the shock shaft is thicker. Those are PL specific and are intended to be used with that PL style shock, which the shock assembly can be used on the HB kit.
snwchris is offline   Reply With Quote
Old 07-06-2015, 09:44 AM   #9503
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The "new" b5m rear V2 shafts "should" work. They taper down for a 2.5mm ID on the piston, which is the same as the D413 pistons ("I think").
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-06-2015, 01:18 PM   #9504
nitro2be's Avatar
Since most of us run 100k in center diff would you also run 100k in center on 8th scale e buggy? I really like the way 100k is on this d413 and thinking of doing 8th e buggy. Anyone know what ty runs in his diffs for ebuggy?
Old 07-06-2015, 01:40 PM   #9505
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Center Diff in E-buggies typically run from 3-7K.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 07-06-2015, 01:51 PM   #9506
nitro2be's Avatar
Yes, I'm seeing that on set up sheets, but if 100k works so well in this little d413 with 3 gears diffs why would it be so different for 8th scale ebuggy?
Old 07-06-2015, 02:41 PM   #9507
Suspended
They are two different scales, different oils are going to be optimal. By all means try 100k in the center diff of your electric 1/8th scale, you may like it. Back when people were first converting 1/8th scales to electric, my buddy built a super over powered car and it handled like crap. The motor made way more power than a nitro engine, so he started upping the center diff oil and it started to get better. The thickest fluid he could get was 300k. It worked okay, so I suggested just filling the center diff with JB Weld. Full time 4wd worked well for his super over powered car. Now that 1/8th scale specific electronics exist, setups more closely to what is normal in a nitro car.
Mantis Toboggan is offline   Reply With Quote
Old 07-08-2015, 09:21 AM   #9508
aeMatt's Avatar
Just finished building my D413
Hot Bodies D413 1/10 4WD Buggy-d413.jpg
Team Associated\\\\\\Reedy\\\\\\JConcepts\\\\\\Airtronics\\\\\\Upgrade RC
www.rc10.com/www.jconcepts.net/www.airtronics.net/www.upgrade-rc.com
aeMatt is offline   Reply With Quote
Old 07-08-2015, 09:22 AM   #9509
aeMatt's Avatar
Another picture with the body off; excited to get it on the track.
Hot Bodies D413 1/10 4WD Buggy-d413-2-.jpg
Old 07-08-2015, 09:41 AM   #9510
Suspended
Looks good. You may want to get a different servo horn though. If you want to run an aluminum horn, the HB horn is a direct fit.
