Hot Bodies D413 1/10 4WD Buggy
#9304
Getting my D413 today
I only been in this sport about two months running a B5M Lite but I wanted to try 4x4 so tonight I am getting my D413 kit and I am going to have the following:
ESC and Motor - Reedy Blackbox and Reedy 6.5 Motor
Remote - Spektrum DX4R Pro 4-Chan
Servo - Spektrum S6100 High Voltage Surface Servo
Batteries:
Team Orion 2S "Carbon Pro" 100C Li-Poly Shorty Pack Battery w/4mm Tubes (7.4V/4500mAh)
I would love to hear what you think of my setup, what gearing I should use and also any tips on driving a 4x4 for the first time
Batteries:
#9305
If you haven't already looked, the first page of thread has a lot of great info, tips, tricks and even a gearing chart listed. Gearing will depend on size and/or type of track running on.
As for setting up the car, I would look thru the link to see if something is similar to your track area. A lot of people have started with the original Ty's Reedy Setup from 2014. It makes the car very easy to drive and the car can be pushed hard. Depending on your track type, if medium or high bite you might have to change diff fluids. I run on Med/High bite and run 7-100-5 for diffs.
http://www.petitrc.com/setup/hotbodi...cloneD413.html
#9306
Johnathan, I would pick these up for your car.
http://www.avidrc.com/product/5/acce...cessories.html
#9307
#9312
Team Tekin
#9314
Thanks guys. I have already looked at the VRC ones, but I was just wanting to use regular pistons. The VRC pistons seem cool, I just don't like that they are thicker than the normal piston. This causes the lock nut to not lock on the shock shaft.
I will look at rcshox again. I just saw the steering rack. I will look harder.
#9315
i have kind of settled on 31/69 with team powers motor timing at "2"
i am running the exotek 69 spur, and it is LOUD ! even with a full heat i got no problem hearing my car ....unfortunatly in my opinion the more you can hear it the more power is wasted in making the sound....today it will get torn apart get some fresh bearings and checked out
our local fast guy can with his 44.2 nail 16.2-16.6 lap times, where i struggle with 17 flats...he can tripple out...i cant.....on the upside i got same amount of laps (19) as the 44.2, and a 44.3 running mod motor....so thats cool....
