Like Tree29Likes
Old 05-29-2015, 09:11 PM   #9286
Originally Posted by Mantis Toboggan View Post
Look at pictures of other peoples cars on here. I think you're gonna find your spring collars are in the same place as everyone else. What ride height are you running?
There are lots of other adjustments to make. What setup are you running? What tires do you run?
Drew moller Chico set up. Aka typo and chain links
Last edited by bosborne77; 05-29-2015 at 09:12 PM. Reason: I didn't mean to post it
bosborne77 is offline   Reply With Quote
Old 05-29-2015, 09:11 PM   #9287
Drew moller Chico set up. Aka typo and chain links. I run the black sway bar up front
Old 05-29-2015, 09:26 PM   #9288
Has anyone tried the new proline buggy shocks on their d413? Picked up a set but have found the fronts are a fair bit shorter then the hb units. I had assumed that Ty being a proline driver that the d413 would have been something they really tested these for...
robbie_gtc is offline   Reply With Quote
Old 05-29-2015, 09:56 PM   #9289
Suspended
Where in the corner does it feel like it has too much steering? Is it that the steering is too aggressive, or do you not have enough rear grip? Are you saucing the tires?
Mantis Toboggan is offline   Reply With Quote
Old 05-29-2015, 10:43 PM   #9290
[QUOTE=Mantis Toboggan;14031773]Where in the corner does it feel like it has too much steering? Is it that the steering is too aggressive, or do you not have enough rear grip? Are you saucing the tires?
Initial. It's like taking the car out on pavement on the front. The rear doesn't slide out it did but I got that fixed. Yes
Old 05-30-2015, 12:49 AM   #9291
Suspended
So you're saucing the tires, and feel the car is too aggressive? Maybe stop saucing the fronts?
What are you running for front toe? If you're running any toe out go to 0, if you're running 0 go to 1 of toe in.
Maybe look into a different setup. The Drew Mo setup clearly says for a tight track, probably gonna have lots of steering.
Old 05-30-2015, 12:51 AM   #9292
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by hacker View Post
just built mine after a couple of years umming and erring.....
seems to be quite a bit of drag in the drive train, not surprised however considering the weight of 3 gear diffs.
wouldn't think this car would be good for 13.5 / 17.5 blinky!
It's actually quite fast in 13.5 blinky. I beat most of the mod guys that can't handle their horse power
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-30-2015, 12:59 AM   #9293
STLNLST's Avatar
Originally Posted by Cygnus X View Post
motor is a team powers and they like timing...a lot of it !
center diff is thick, but my thought on that is the b44.2 gets by with a slipper + spool....so i wanted to try 200k just for the fun of it, and its awesome, so much forward bite and ton of steering.
i pretty much run josh close's setup on this car (it was his car :-)
so 20k front, 200K center, 7k rear, he ran 50w in the shocks, with 2 hole 1.5mm holes, car drives and feels really good...had too much steering but thats what dual rate is for
i run exotech 69T spur and 31T pinion, max timing 13.5, car comes off at 172F after 6-7 minutes which is a little on the hot side but ok
i have tried 28-29-30-31t pinion, and 31 gave best result that day
since my car weighs the same as a b44.2....then thats not the problem....i am thinking (i know its hard to believe that i am LOL) but theres a ton of rotating mass and that has to hurt my acceleration.
so the only way i see the d413 working in 13.5 is to lower weight
yeah i am gonna be there for the belt race....norcal is my home away from home, im in one of the office pitspots come say hi
There's something else missing here as I don't have an issue in 13.5 with this car. Josh ran 20K front diff fluid?
Old 05-30-2015, 09:01 AM   #9294
mvrk28's Avatar
Originally Posted by STLNLST View Post
It's actually quite fast in 13.5 blinky. I bear most of the mod guys that can't handle their horse power
Watch it....
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 05-30-2015, 09:21 AM   #9295
Ok thanks.
Old 05-30-2015, 09:36 AM   #9296
yup he did....whats your gearing ?
Cygnus X is offline   Reply With Quote
Old 05-30-2015, 09:40 AM   #9297
moto67e's Avatar
Trader Rating: 39 (100%+)
Really liking this buggy. I'm running Ty's set up for OC/RC with a 7.5 Reedy motor. I've tried a bunch of different tire combos and the Pro Line Electrons have worked the best so far. I didn't drive it very well last night but it was still lots of fun.
moto67e is offline   Reply With Quote
Old 05-30-2015, 01:41 PM   #9298
nitro2be's Avatar
good looking car. I bet with a 7.5 that's it's smooth drive
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 05-31-2015, 09:59 PM   #9299
STLNLST's Avatar
Originally Posted by mvrk28 View Post
Watch it....
Old 05-31-2015, 10:02 PM   #9300
STLNLST's Avatar
72/31 but we run different motors. I run Tekin and they don't like to run max timing like the Team Powers motors.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
