Like Tree31Likes
Old 05-27-2015, 11:28 AM   #9256
What is the purpose of the set screws that go into the shock tower mount? Should I tighten just enough so the sway bar doesn't bounce around?
Originally Posted by kevink123 View Post
you are correct on the collors need to be free side to side as well as the set screw that goes into the shock tower mount to not pinch the bar and cause a bind. Basically you want your suspension free and both of these things are noticable if you take your tires and shocks off and try and raise and let the arms fall on there own.
The sway bars have nothing to do with on or off power as you described however it does effect steering on both and traction. If you run to thick of a sway bar you will not have the same low speed steering as the car won't be able to roll and you will loose traction as well for the same reason. Set your sway bars up for traction levels in the corners, if your traction rolling then thats an easy adjustment to just go up in sway bar size and still have the same shock package, you need the car to carve corners without traction rolling, "tires stay in contact on all four corners but the actual car leans". To soft and you will have tons of steering and traction roll and to hard and the card will slide and not hook up. I go to two tracks one is lower bite and I only run the rear copper bar no front sway bar with the same shock oil and on the other I put both black sway bars on and the two cars cannot be drove fast on the other track.
adamlrivard is offline   Reply With Quote
Old 05-27-2015, 12:06 PM   #9257
nitro2be's Avatar
Yes
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 05-28-2015, 06:47 AM   #9258
Motorman007's Avatar
Trader Rating: 78 (100%+)
HOW HAS IS HE MOUNTING THIS FAN
Is the tape that strong?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 05-28-2015, 07:06 AM   #9259
mvrk28's Avatar
Servo tape most likely. I use the stuff with the red wrapping on it. Mine is stuck on and I crash a lot.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 05-28-2015, 07:22 AM   #9260
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by nitro2be View Post
Just my experience, just average joe. The older set ups are little ,very little bit calmer.i would think # 5 steering ack plate things and radio adjustments would help smooth out the car more than a different setup sheet.
part number for these?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 05-28-2015, 07:32 AM   #9261
You have a link sir
Old 05-28-2015, 07:37 AM   #9262
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
You have a link sir
use the scotch black tape.
http://www.amazon.com/Scotch-414-DC-...ded+tape+black
or the scotch 5lbs clear.
http://solutions.3m.com/wps/portal/3...294268138&rt=d
both can be purchased at walmart. I use the clear for esc/receiver and black for fans. black is a bit strong for esc/receiver. I use a heat gun to warm the tape before applying and use some pressure for a minute to help it bond
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-28-2015, 08:35 AM   #9263
nitro2be's Avatar
Hbs112805 mellow
Old 05-28-2015, 09:07 AM   #9264
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Hbs112805 mellow
$21.00 wow thats up there, any one have a cnc machine that can make this i got $12 for some! lol
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 05-28-2015, 09:29 AM   #9265
Thanx Boss will get some today.
Old 05-28-2015, 10:06 AM   #9266
nitro2be's Avatar
+tax and shipping. Lol
Old 05-28-2015, 10:12 AM   #9267
lmao!!! exactly - thats crazy for such a small piece of carbon
Old 05-28-2015, 12:14 PM   #9268
HB carbon fiber has magical properties... that is why it is 2x - 5x as expensive as any other carbon fiber!
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 05-28-2015, 12:51 PM   #9269
LMAO
Old 05-28-2015, 02:15 PM   #9270
nitro2be's Avatar
Talking
Now i feel better cause I bought one to months ago. Lol. I was starting to feel like a dumb ***.
