Like Tree42Likes
Old 05-21-2015, 04:33 PM   #9211
VegasHB's Avatar
Originally Posted by yzracer758 View Post
No...
The car will be harder to drive on a slippery track with thicker fluid.
Example:
Tessmann Worlds setup (Sugar Track/Super High Bite): 300k Center oil
Tessmann OCRC setup (Indoor clay Medium/High Bite) 100k Center Oil
First...I friggin love Tekin and your customer service
Second...You're correct, seems in general that the looser the track the lighter the oil, however it comes down to an acceleration vs driveability thing on loose tracks. Thicker oil increases acceleration overall so the OP might be hunting for something more than just the center diff.
Here's what I have from the googles
Originally Posted by thegoogles
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too
much power and sometime “cook” the oil in the center
differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 05-21-2015, 10:44 PM   #9212
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
torrence, if you still follow this thread, can you tell me if you plan on selling the aluminum shock standoffs separately? one of mine broke.
RC*PHREAK is offline   Reply With Quote
Old 05-21-2015, 11:37 PM   #9213
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by MasiisaM View Post
You will have fun! the track layout is fast and flowing. The double in the middle is REALLY easy to overshot. You can whip it pretty good as the lip pops yea.
FYI I changed his 2015 Ready race set up just a tad for this layout.
2 mm of limiters in the rear shocks and 1 degree of anti squat to keep the back end from coming around off power on the sweeper/roller after the straight.
I use Gold Dirt Webs front and rear with AKA foams.
Thanks for the info :-) is any one running AKA chainlinks?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-22-2015, 07:43 AM   #9214
Another nice to have would be the shock eyelets. Having to buy an $8 shock plastics package and throw away everything except the eyelets is hard to swallow.
Also, I can't seem to find diff gaskets without buying a spur gear. Am I just looking in the wrong place?
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 05-22-2015, 09:55 AM   #9215
MasiisaM's Avatar
No worries...With the shortage of dirt webs...its pretty common that the go to are Chainlinks.
Haven't tried them on the D413..but i have on my mod 2wd. The difference is super minimal at best. As long as they're broken in...they will be just fine.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 05-22-2015, 09:59 AM   #9216
MasiisaM's Avatar
-Chris
+1...i looked all around and they don't seem sell the gasket or o-rings separate. Which is annoying. When I change the fluid those are part of the rebuild.
I have some Kyosho P5's coming to see how those do on the next rebuild..currently I'm just reusing the gasket.
Thanks to:
Old 05-22-2015, 01:54 PM   #9217
STLNLST's Avatar
We will be down your way next Friday. Are you racing? Will have the wheeler there for some mod testing. Up here we run a 13.5 blinky with the mods and always finish ahead.
Old 05-22-2015, 02:14 PM   #9218
MasiisaM's Avatar
Wish I was...Next weekend has negative ghost rider all over it..moving sucks!
ohhhh 13.5 blinky? TBO...its freaking stacked down here and the track was designed for the "Stock Nats" so it's pretty open and fast. I would say add some timing for sure.
Dont know how long you're down here...but if you have time...try to also hit up IERC. It's another great indoor track down here. It's a little over an hour away(a bit out of your way) They also race on Sat, but open practice is on Sunday.
If you're heading back on Sunday...then there is a much smaller track on the way back up (off the 5) well really off the 14..just a few minutes though..but same direction @ SCVRC. Their racing starts at 2. The program is pretty short.
Thanks to:
Old 05-23-2015, 03:23 AM   #9219
STLNLST's Avatar
Finally put a mod in the buggy and it's as smooth with a 7.5 as it is with a 13.5 I think I want more power because I know the car can handle it
Old 05-23-2015, 12:53 PM   #9220
mvrk28's Avatar
Broke a turnbuckle last night in a bad crash, thought I would have broke a lot more though. Ordered up some Lunsfords, anybody have any tips on using these?
mvrk28 is offline   Reply With Quote
Old 05-23-2015, 05:14 PM   #9221
Schwarta's Avatar
Does anyone know if there's a problem soldering the motor wires from the back, or do they need to be routed around to the front? I've installed my esc behind the motor. Only problem is the wires hitting the body shell.
Schwarta is offline   Reply With Quote
Old 05-23-2015, 05:19 PM   #9222
Suspended
What is the orientation of your solder tabs? If you were looking at the end of the motor where the solder tabs are while the motor is in the car are the tabs at 12 o'clock?
Mantis Toboggan is offline   Reply With Quote
Old 05-23-2015, 05:23 PM   #9223
Schwarta's Avatar
Solder tab are approximately 1:30-2:00 (With 12:00 straight up) towards the outside of the car.
I think I just need to shorten the wires, I've given them a bit too much slack.
Old 05-23-2015, 05:34 PM   #9224
STLNLST's Avatar
Take that 5.5 out......lol car my car was stuck. I felt like Ty himself would have been behind me.....lol car was finally locked in so I started throwing motor at it. I wants to be driven hard.
Old 05-23-2015, 05:43 PM   #9225
Suspended
1:30 to 2:00 to the outside would be 10:30 to 11:00. How much extra wire do you have in your car?
