Like Tree28Likes
Old 05-01-2015, 05:06 PM   #9046
STLNLST's Avatar
Trader Rating: 19 (100%+)
Got my new Factory RC goodies to compliment this sexy Schelle aluminum chassis. All I can say is OMG this feels waaaaa better than my Yok ever did. In the pic of the Factory RC pieces I flipped the center piece to try and show you the angled cuts it has underneath. The battery mount is helpful for those of us that have fans mounted directly to the battery and we ask a friend to put your car down once it's done charging.
Hot Bodies D413 1/10 4WD Buggy-20150501_165735.jpg   Hot Bodies D413 1/10 4WD Buggy-20150501_165759.jpg
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-02-2015, 04:07 AM   #9047
rangerjkb's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to rangerjkb
Originally Posted by nmdesertracer View Post
Time to move out of Novice class!! J/K congrats
yeah, no kidding, lol! Very glad the car worked so well and is fun to drive, looking forward to having some great races in the future with it
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 05-02-2015, 06:17 PM   #9048
Dal
Dal's Avatar
Send a message via Yahoo to Dal
Dumb question from hb noob
how do I do my pinion gear grub screw up, after the first motor plate is put onto motor?
do i need to drill a hole in the motor mount (that screws onto the motor) to get to the grub screw?
Its ok if im using a small pinion, as the gear fits through the hole in the motor plate, but any bigger pinion, will need to be put on motor after the motor plate.
Dal is offline   Reply With Quote
Old 05-02-2015, 08:49 PM   #9049
chadg's Avatar
Trader Rating: 16 (100%+)
This seems to depend on what type of pinion you run. I had to take a dremel and notch out a spot to get access at the grub screw on the pinion.
chadg is offline   Reply With Quote
Old 05-02-2015, 09:18 PM   #9050
nitro2be's Avatar
+ 1. 21 pinion Robinson
nitro2be is offline   Reply With Quote
Old 05-03-2015, 03:32 AM   #9051
egobrkr's Avatar
Trader Rating: 26 (100%+)
Well I got to race with the new schelle +4 chassis Saturday at our first round of summer seires. I first impression was it's ok and didn't think it was that good of an upgrade. I decided to run the race with it and see if it grew on me. I qualified 6th out of 3 full heats in the first round. The 2nd round I did not do so good and dropped to 8th so still in the A main. In the main the track was a little dryer then is was early in the day. I ended the day with a last place finish in the A main.
In my opinion the chassis did not make the buggy better. It jumped nose up and I lost too much corner entry steering. It did make the buggy more stable but too stable for me. It took too much of the nimble out of the buggy. I am going to give it another try in 2 weeks just to be sure that I still feel the same way. This is just my opinion on this chassis and many others find this chassis to be a great improvement over the stock chassis.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 05-03-2015, 08:45 AM   #9052
STLNLST's Avatar
What setup are you running? The chassis pushed for me running the setup I started out with but after two changes after my first battery the car was clearly the fastest 4wd on the track. The car is stable and still has that nimble feeling. I'm sure an adjustment here and there will have you where you want to be..
Old 05-03-2015, 04:07 PM   #9053
Trader Rating: 39 (98%+)
So I did some maintenance on the buggy to get it ready for racing tiday. I redid the diffs so they were 10k front 100k center and 5k rear. Not sure what was in there before. The car did seem to rotate through the corners better and I was able to carry more speed. I did notice that the front tires were ballooning under full power. Should I go up on the front diff fluid or is some of the ballooning expected?
The changed the shock fluid as well. Shocks are set up as emulsion. Front I put 40 wt with stock pistons and silver springs. Rear I put 35 wt stock pistons with yellow springs. The car seemed to bottom out easily on the jumps. Would it be better to go higher on shock fluid or do a heavier spring change?
Thanks for the help.
Team associated sc5m
Team associated t5m
Hobby wing
Trinity
Futaba 4px
wheres_yogi is offline   Reply With Quote
Old 05-03-2015, 04:28 PM   #9054
egobrkr's Avatar
I am running my own setup. I am going to give it another try and see if I can make it better with some changes.
Old 05-03-2015, 05:10 PM   #9055
Default spare shock shaft treasure hunt
Bent a front shock shaft. My bad, big jump,llaunched crooked and hit a metal polemic mid air.
Anyway, AMAIN on back order until at least May 15. Any other place or any other brand that can swap in directly?
dblhelx is offline   Reply With Quote
Old 05-03-2015, 09:21 PM   #9056
nitro2be's Avatar
I'd go up to 40 in rear with stock pistons and the springs are fine.what would really help is the 2 hole pistons then u could run 35 in rear..I'm 40 35 and 2 hole pistons 1.6 1.7 works great and my diffs are same as yours and works great.
Old 05-04-2015, 04:18 AM   #9057
Dal
Dal's Avatar
does anyone know of a 14mm hex, that will fit on the front axles and rear, so I can run durango or xray wheels, as I have heaps of them.
Or a mod that will work, im looking at drilling out the durango hexs
Old 05-04-2015, 05:40 AM   #9058
snwchris's Avatar
With my Schelle chassis I'm running the older Reedy Setup with minor adjustments. Diffs 7-100-5 on med-high bite. I also put my ESC in back and RC up front, the battery moved back one position as well.
snwchris is offline   Reply With Quote
Old 05-04-2015, 06:16 AM   #9059
To keep the front tires from ballooning under power you would need to go up on center diff oil. I'm surprised to hear that. I just went up to 100K in my center and that thing is stiff. Haven't run it yet though.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 05-04-2015, 08:50 PM   #9060
Billy's Avatar
Default Cooling fan for the motor
Under the hood photos of Tessman's car show he is using an additional cooling fan (Muchmore) for the Orion Motor. Is the fan pulling heat away from the motor or blowing cool air on the face of the motor?
Billy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
