Like Tree28Likes
Old 04-27-2015, 04:47 PM   #8986
egobrkr's Avatar
Trader Rating: 26 (100%+)
So I ordered a schelle +4 chassis. I think the buggy drives really good with the stock chassis and some setup changes. Numerous people have said the +4 chassis makes a big difference. I will report back after I race with it this weekend.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-27-2015, 06:30 PM   #8987
nitro2be's Avatar
Originally Posted by MasiisaM View Post
A-main has the spur gears in stock
The spring perches had me for awhile...No joke I was loosing one every time I drove the car...It was driving my crazy.
I knew something had to be up...cause I never really heard about on here or at the track. So I pulled out the manual and sure enough..there is a right way and wrong way to install the bushing to the shock eyelet..which if you put it on backwards(like i did) the spring perches had the slot facing forward and not backward.
Once I fixed that...i haven't had one pop off.
yep, I figured that out too.i felt like a genius. Lol.still have not put mine on right after I paid for exotek .maybe I'll do that now.thanks for the reminder
nitro2be is offline   Reply With Quote
Old 04-27-2015, 08:44 PM   #8988
Schwarta's Avatar
Hey all, couple of questions. Picked up a used d413, it came with the schelle extended chassis, what effect will it have on handling? I'll be racing on a low/med grip indoor clay surface.
Also, I want to get some of the aftermarket shock pistons, any preference of the VRN or Rcshox? I plan on getting the 1.6 and 1.7, 2 hole.
Thanks.
Schwarta is offline   Reply With Quote
Old 04-27-2015, 10:36 PM   #8989
Originally Posted by mvrk28 View Post
That was my question, basically the 72 tooth is out of stock for the Exotek. So my question was what would the effects be of a 68, because it's available.
You may not get a 20 or even 21 pinion to work with a 68 spur... someone said that 19 pinion was the smallest they could fit with the 72 spur, if you go to 68 spur, then the pinion would need to be bigger... like 4 teeth to make up the distance.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 04-28-2015, 05:35 AM   #8990
mvrk28's Avatar
Great point I didn't even think about that.
mvrk28 is offline   Reply With Quote
Old 04-28-2015, 05:36 AM   #8991
mvrk28's Avatar
Thanks.
I run VRP in my car highly recommend
Old 04-28-2015, 06:47 AM   #8992
snwchris's Avatar
One of the best investment for this buggy by far. Its truly does make a difference, I've had mine for a few weeks now and dam wish I would have bought it months ago... LOL
Also when I did the chassis change over, I changed up the position of the RX and the ESC. My ESC is now right behind the motor and the RX is up front of the motor. When I scaled the buggy it was nicely balanced that way.
snwchris is offline   Reply With Quote
Old 04-28-2015, 07:52 AM   #8993
MasiisaM's Avatar
Thanks.
If you don't want to drill them(which is kinda fun btw) then i went with VRP. The quicker rebound/design worked really well at my track. I tried Rcshox...garbage. The tolerance was off on my set and the oil holes were oblong.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 04-28-2015, 08:02 AM   #8994
Billy's Avatar
Originally Posted by nitro2be View Post
Xra362290
Excellent Thank you!
Billy is offline   Reply With Quote
Old 04-28-2015, 08:19 AM   #8995
MasiisaM's Avatar
I know right..For sure it's my fault..But maybe...just maybe the instructions could be a little more direct.
Thanks to:
Old 04-28-2015, 08:53 AM   #8996
Trader Rating: 15 (100%+)
I have been using the Schelle prototype aluminum chassis for a couple weeks now and here is my honest opinion. The chassis itself is diffrent then the avid one as the Schelle is milled out to allow flex. Weight wise of the top of my head I believe the car weighed around 30-40grams more and the car on the bench felt it had the same flex as the original chassis.
When building either +4 chassis make sure and put a O-ring on each side of the front center driveshaft inside the outdrives so it doesn't fall out.
On the track- I run on a smaller low to med bite track where we use highly sauced M4 electrons. The car in all honesty felt way better right of the start, it felt more planted all over and I didn't loose any traction from before also I noticed the car would let go of the corner alot better instead of wanting to keep turning out of the corner. After running it for 3 batteries I decided it needed alittle more shock oil weight so I went up 5 wt front and back "using 1.6F 1.7R" and the car just got better and easier to drive hard. After another race and practice day i ended up going from 10k front diff to 7k and usually this makes the car hard to drive but with this chassis on it the car came into and out of corners much faster and was able to hold the throttle longer on the sweeper which resulted in faster times.
Overall this is a quality product and something I would recommend for any track not just high bite. Also make sure and grab a chassis protector.
kevink123 is offline   Reply With Quote
Old 04-28-2015, 09:07 AM   #8997
the incubus's Avatar
Trader Rating: 17 (100%+)
Interesting how initially, outside the shock caps, this car was PERFECT in every possible facet, by far the easiest wheeler to drive and far and away the best wheeler to date. Now all these aftermarket accessories are released and "issues" are being resolved?
This is by no means an attack or insult on anyone, just pointing out contradictions I find humorous.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 04-28-2015, 09:28 AM   #8998
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Ty is not running the kit chassis. So it is not that perfect, lol. Otherwise, my main issue was shotty parts support and really soft plastics.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-28-2015, 09:30 AM   #8999
The car initially is really good, but has a ton of steering "thats why you see people using 3.5 toe in on a high bite track" also why HPI came out with a +5 ackerman.
The chassis is by no means a must have but for the people looking to upgrade there car then this is for them. I ran the box stock car at cactus "shock caps and all" and it was really good but this just takes it up a notch IMO.
Old 04-28-2015, 10:39 AM   #9000
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Wildcat1971 View Post
Ty is not running the kit chassis. So it is not that perfect, lol. .
So has TY told you if the non kit chassis is faster than stock?
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
