Like Tree35Likes
Old 04-27-2015, 04:07 AM   #8971
Trader Rating: 15 (100%+)
Originally Posted by STLNLST View Post
Thanks for the info.
Not sure if setup sheet mentions it, add .5mm under steering rack for a touch of bump steer. Found it helpful creating faster lap times.
uncle everett is offline   Reply With Quote
Old 04-27-2015, 06:56 AM   #8972
boudin4evr's Avatar
Trader Rating: 18 (100%+)
on the xb4 short bushings, are they just shorter and or smaller internal diameter?
I was gonna cut mine, but if the Xrays are smaller in internal diameter that would be even better! thanks
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 04-27-2015, 08:01 AM   #8973
Originally Posted by Yeti AS3 View Post
IMO the rack is the only must have. I am by no means a great driver and have never found a need for any other alum bits.
I agree with this. The Exotek stuff is nice to look at it but I haven't found a real need for most of it. I bought a spare HB spur when I got my kit but my original is still doing just fine.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 04-27-2015, 08:31 AM   #8974
Billy's Avatar
Originally Posted by nitro2be View Post
Yes, out of the box slop.as already said exotek rack and I use xb4 short bushings for front hub carriers big difference. I bought spare parts and still have not used them except one front tower and I've had my buggy since December and go to track almost every week.
Nitro2be: do you have the parts number for the xb4 short bushings you mentioned to take out some slop? Thanks in advance.
Billy is offline   Reply With Quote
Old 04-27-2015, 08:44 AM   #8975
the incubus's Avatar
Trader Rating: 17 (100%+)
^^^ I thought racing slop was fast? LOLOL
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 04-27-2015, 09:17 AM   #8976
nitro2be's Avatar
the fit tighter in the hub and are correct length to tighten without slop.you can cut down, I did and little better but not as good as xb4 ones.all depends on what u want to spend.
nitro2be is offline   Reply With Quote
Old 04-27-2015, 09:56 AM   #8977
nitro2be's Avatar
Xra362290
Old 04-27-2015, 12:28 PM   #8978
Thanks for all the feed back! I really appreciate it
RacingCraze21 is offline   Reply With Quote
Old 04-27-2015, 12:45 PM   #8979
mvrk28's Avatar
-Chris
I had issues with the stock spring perches, and not just the mud guard version. I have not had a single spring pop off or an eyelet pop loose since I upgraded to the Exotek version. I'm starting to think the wing mounts were a bad call for guys like me who have a tendency to tumble here and there, they rip through wings. I do love my Exotek spur gear, and will definitely be running it as soon as I get my hands on another gear.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 04-27-2015, 12:56 PM   #8980
MasiisaM's Avatar
A-main has the spur gears in stock
The spring perches had me for awhile...No joke I was loosing one every time I drove the car...It was driving my crazy.
I knew something had to be up...cause I never really heard about on here or at the track. So I pulled out the manual and sure enough..there is a right way and wrong way to install the bushing to the shock eyelet..which if you put it on backwards(like i did) the spring perches had the slot facing forward and not backward.
Once I fixed that...i haven't had one pop off.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 04-27-2015, 01:09 PM   #8981
mvrk28's Avatar
I saw that gear on amain but it's a 68 tooth, I run a 5.5 in my car so I run the 72.
VANT LIPOS
Old 04-27-2015, 01:14 PM   #8982
mvrk28's Avatar
Can somebody school me a little bit on gearing?
I currently run 72/21 with a 5.5 motor, my FDR is 11.34 and some change. If I were to run it at 68/20, it would be 11.25 or 10.71 at 68/21. What are the effects of changing to the 68 vs the 72? I want the car to continue to run cool and kick ass without being uncontrollable.
VANT LIPOS
Old 04-27-2015, 01:37 PM   #8983
Chr1s's Avatar
68/20 would be almost negligible. 68/21 would be faster. Why bother changing the spur? Just use a different pinion. I think they make the small spur for 13.5 motors so you can fit a larger pinion on the mount.
going smaller on the spur is like going bigger on the pinion.
In conclusion don't waste your time.
Chris Kline
Chr1s is offline   Reply With Quote
Old 04-27-2015, 03:12 PM   #8984
STLNLST's Avatar
Trader Rating: 21 (100%+)
What is the internal ratio of the tranny?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-27-2015, 03:42 PM   #8985
mvrk28's Avatar
That was my question, basically the 72 tooth is out of stock for the Exotek. So my question was what would the effects be of a 68, because it's available.
VANT LIPOS
