Like Tree28Likes
Old 04-17-2015, 11:11 AM   #8896
mvrk28's Avatar
Originally Posted by MasiisaM View Post
Maybe start there and see how it works for you...
Whats the grip levels at your track?
If it was me I would also try no can timing...with a 5.5 it will help in being smoother. By going to the mildest curve and then adding some back in can timing kinda works against each other... with really just adding heat.
For sure play with Throttle profiles...but don't forget to also play around with throttle min and current limiter.
The trick is to give that thing the most usable power down low...cause that 5.5 will be a monster on top.
I'd say my track is medium traction. I'm going to run it at 0 timing and throttle profile 1, I'm running my 10.5 at throttle profile 2. I run 0 drag brake with a +5 on push control. Thanks a lot for your help, don't be surprised if I PM you to pick your brain!
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 04-17-2015, 11:22 AM   #8897
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Questions??
Originally Posted by egobrkr View Post
So wanted to share an issue that has come up a few times running my buggy. The front sway bar comes out of the plastic end holders. I'm not sure if anyone else is having this issue but it is annoying me. I will buy some new ends and see if that works or see if I can find aluminum ones that will work. I try not to tighten down the set screw because it's plastic.
Speed passion 5.5 with r10 esc. 5 turbo (just never changed it) 22 pinion, no motor fan, 60 deg air temp. Comes off at 155ish after a full pack.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 04-17-2015, 11:41 AM   #8898
Trader Rating: 39 (98%+)
Any idea what would be a good starting point to gear with an orion r10 with a 7.5?
Team associated sc5m
Team associated t5m
Hobby wing
Trinity
Futaba 4px
wheres_yogi is offline   Reply With Quote
Old 04-17-2015, 12:23 PM   #8899
mvrk28's Avatar
25/72
VANT LIPOS
Old 04-17-2015, 01:30 PM   #8900
MasiisaM's Avatar
Hey no worries...for sure ask away..
On med bite i would start with what you would want to try first...
Then try 80-85 on the current limit..and maybe go down to 1-2 on min throttle. See how that feels...and compare your lap times to see if it's faster.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 04-17-2015, 02:30 PM   #8901
[QUOTE=egobrkr;13964790]So wanted to share an issue that has come up a few times running my buggy. The front sway bar comes out of the plastic end holders. I'm not sure if anyone else is having this issue but it is annoying me. I will buy some new ends and see if that works or see if I can find aluminum ones that will work. I try not to tighten down the set screw because it's plastic.[/QUOTE
Me and my bro had the same problem with our buggys last weekend. I'm going to try the 4-40 screws and see if that helps.
daviboy is offline   Reply With Quote
Old 04-17-2015, 03:37 PM   #8902
jhautz's Avatar
Trader Rating: 85 (100%+)
I had that happen too. I just cranked the set screw down and it has been good ever since.
jhautz is offline   Reply With Quote
Old 04-18-2015, 06:42 PM   #8903
Default shock caps
All this talk about aluminum shock caps. Does any one know where I can get some stock plastic caps?
jjl1 is offline   Reply With Quote
Old 04-18-2015, 08:33 PM   #8904
Default Front nose piece
Maybe I've had one too many beers while I build this......but for the life of me I can't figure out an easy way to install the little front nose body piece. Do I just finesse it/ram it through the shock brace?
dblhelx is offline   Reply With Quote
Old 04-18-2015, 08:50 PM   #8905
Yes...
nordfink is offline   Reply With Quote
Old 04-18-2015, 08:57 PM   #8906
nitro2be's Avatar
Ram it after another beer. Top to one side then back in straight
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 04-18-2015, 09:52 PM   #8907
Suspended
Or you can take the tower mount off and install the nose piece.
Mantis Toboggan is offline   Reply With Quote
Old 04-18-2015, 11:06 PM   #8908
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
^^^^this. it's only 4 screws.
RC*PHREAK is offline   Reply With Quote
Old 04-19-2015, 09:15 AM   #8909
nitro2be's Avatar
Old 04-19-2015, 12:14 PM   #8910
To keep the doucheness going....it's actually 6 screws....have to take shock screws off to get brace totally off.
Almost time for beer-O-clock.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
