Like Tree31Likes
Old 04-10-2015, 09:55 AM   #8791
mvrk28's Avatar
Originally Posted by MasiisaM View Post
Ahhhhh...I got yea..
Report back when yea have a day on it.
Will do, Fantom actually recommended a few changes to the motor. Went with a 5.5 (my call there) but they said the 13mm rotor is going to have a lot of torque and if anything go with the 12mm comes stock with a 12.5mm so I'm going to run stock for now and maybe pick up the 12 and 13 down the road. They actually recommended stock bearings for off road, they said the ABEC 7 bearings are better suited to on road cars so I deleted those.
I kept the Teflon shims and aluminum timing ring, will mess with rotors later.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 04-10-2015, 10:32 AM   #8792
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
a 5.5 has a crap ton or toque and speed, you dont need more rotors
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-10-2015, 10:57 AM   #8793
Chr1s's Avatar
I use the trinity d4 5.5t, which is basically the same as the ion v4. the power delivery is very good. It not overally torquey but still fast when you need
Chris Kline
Chr1s is offline   Reply With Quote
Old 04-10-2015, 11:00 AM   #8794
Chr1s's Avatar
Also my lap times improved when i went from a reedy 6.5 to the d4 5.5
Chris Kline
Old 04-10-2015, 12:30 PM   #8795
BmainStar's Avatar
It's amazing to me how people want to rag on someone for buying hopups or spending money on their rig ,needed or not,what do you care? This is not a cheap hobby to begin with$1200 min buy in.Some people HAVE more$$$$ than You do!!!Get over it!!!I'm Just amazed his girlfriend supports this Addiction!!!!!Cheers!!!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-10-2015, 02:05 PM   #8796
I just picked up a 413 as my first 4wd buggy. I read through several pages of this thread and I would like to make sure I understand something.
The front wheels from my 22 will fit the front, but they are 1mm narrower than the 4wd wheels. For an average club racer, will that 1mm really make a difference? I would like to use the same wheels to reduce spare parts requirements.
Do most use the same tire front to back or is mismatching common?
For a track where 2wd are using slicks, would you recommend slicks on a 4wd?
ncpantherfan is offline   Reply With Quote
Old 04-10-2015, 02:45 PM   #8797
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
22-4 front are what most run on the 413. I wouldn't run 2wd fronts. You can def run slicks on 4wd...there just a little tuning from pin tire setups. Mismatched tires are common and used for tuning traction and handling. It is especially important on 2WDs.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 04-10-2015, 03:20 PM   #8798
What issues are caused by 2wd wheels? Some manufacturers even lost the same part number. 4wd is totally new to me, I am trying to understand it.
Old 04-10-2015, 03:36 PM   #8799
What about front rims that fit a B44? I just tried to update my old azz B44 but the steering rack is horrible so I gave up and bought the D413.
Now I have nice black rims and a few packs of tires for the B44. The fronts are much skinnier than the rears on the B44. Can I still use these wheels on the D413 successfully???
Thanks peeps. Happy F-ing Friday!!
dblhelx is offline   Reply With Quote
Old 04-10-2015, 03:46 PM   #8800
Yeti AS3's Avatar
The offset is different and will cause handling issues. The 2wd wheel and tire is narrower as well.
I believe the 413 comes with optional smaller hexes to fit the B44 front wheels. B44 rears will fit.
Hot Bodies D413
AE B5m
Old 04-10-2015, 04:21 PM   #8801
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Getting 1 or 2 sets of proper 4wd front tires/wheels will be well worth it. Your $800 investment in kit & electronics will be much more fun when you add $20 worth of the most important thing any car can have, which is tires
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 04-10-2015, 04:24 PM   #8802
Does anyone know the measurement from inside hex to inside edge of wheel? I got several sets of wheels with the car and I would like to check if they are 22 or 413 wheels.
Old 04-10-2015, 04:24 PM   #8803
Dog Runner's Avatar
I'm hesitant to spend $85 on the Schelle CF chassis when the kit just works so well out of the box. For those that have it, is this a must-have or just a nice-to-have? I'm a fairly consistent driver and would be very happy with gaining just .2 or .3 per lap if there's that type of potential in adding this upgrade.
JR
Old 04-10-2015, 06:01 PM   #8804
SeanKewley's Avatar
What would you add to your arsenal of tires if given $200 in gift cards like me?
SeanKewley is offline   Reply With Quote
Old 04-10-2015, 10:04 PM   #8805
Dog Runner's Avatar
All the practice and race time you can buy.
JR
