Like Tree35Likes
Old 04-04-2015, 02:37 PM   #8701
Originally Posted by RC10B4_Mafco View Post
After every 2 race meets the oil in the front and rear diffs seems to leak almost completely. Is anyone else having problems with leaking diffs?
I've recently been having center diff leaking issues. Rebuilt yesterday, we'll see how it goes...
nordfink is offline   Reply With Quote
Old 04-04-2015, 03:08 PM   #8702
My son and I have had a couple leaky diffs from original build, but after refilling and the re tightening haven't had any issues. Not sure if it was just the new tight plastic but they have all been fine since.
CaseyD is offline   Reply With Quote
Old 04-04-2015, 03:15 PM   #8703
I also have been having issues with the center diff leaking even after replacing oring and gasket start leaking on the second day out with it.
turtle189 is offline   Reply With Quote
Old 04-04-2015, 06:15 PM   #8704
Timrod's Avatar
Trader Rating: 47 (100%+)
I actually had the same problem as you guys are talking about. What I found my problem was is that the screws were torqued down into the spur gear to much and actually pushed the screw hole into the diff case, warping the spur around these screws. New gaskets and everything didn't help, I just ordered the exotek aluminum one cause it will never warp and changing spurs gear will be easier.
On another note, I recently went from saddle packs to shorty pack and I was sort of iffy cause my driving style is pretty hard. I was having some setup trouble with the car being unpredictable when I would get on power. Moved the shorty all the way back from being all the way in the front and was the fastest car in the main. My fastest lap was .6 seconds faster than anyone else, and when I would make a bobble I would catch the leader with in a lap or two again. Couldn't make the pass cause his lines were so tight but my car was dialed just from that adjustment either way
Tekno eb48.3
Sponsors:
B-fast diffs ~ ARCS Raceway ~ Protchko R/C Painting
Timrod is offline   Reply With Quote
Old 04-04-2015, 07:09 PM   #8705
snwchris's Avatar
Also make sure your not over filling the diffs and have all the screw tight
snwchris is offline   Reply With Quote
Old 04-05-2015, 11:19 AM   #8706
BmainStar's Avatar
+ 1. Also make sure to grease the oring,both sides of sungear shim and the out drive before it goes into the diff ,I use red syn grease .I have 5 or 6 daze on my diffs with out leakage.Cheers!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-06-2015, 06:40 AM   #8707
I had the exact same issue... over tightened the stock and caused 'dimples'.
Put the exotek spur set up in, and not a drop comes out.
It is slightly louder, but its not a quiet buggy to begin with.
www.bumpsandjumpsrc.com
www.lcrcraceway.com
www.miponline.com
www.serpentamerica.com
Lovell's Lids
wicker9 is offline   Reply With Quote
Old 04-06-2015, 07:27 AM   #8708
Originally Posted by trojanjoe1 View Post
Well my build was going great until it was time to install my motor(tekin red line 6.5) (saddle setup)).... Could not get it to fit. Has this ever been a issue?
I already have 2 sets of saddle packs. But after 2hrs of cussing n such, I switched over to shortty setup.........anyone need saddle packs lmfao
I had the same problem with the Pro4. I ended up using my old Castle Sidewinder.
I think you will be much happier with the shorty setup. I ran the saddles for a while but never had much satisfaction. It was hard for me to get any pitch control in the jumps.
jjl1 is offline   Reply With Quote
Old 04-06-2015, 11:47 AM   #8709
Originally Posted by nicmo View Post
nope, these diffs are pretty solid, no leaks here.
I had a soft plastic center diff spur, the skrews just kept going in consequently leaking. HB send me a new diff and spur no question asked. How great.
bladeys is offline   Reply With Quote
Old 04-06-2015, 01:22 PM   #8710
yeah my front and rear dont leak at all but my center has been leaking, been filling/changing it out every 3 to 4 race days. might order a new gasket and see if that fixxes the issue
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 04-06-2015, 10:44 PM   #8711
Billy's Avatar
Recently purchased this buggy. What drill sizes are 1.7 and 1.6?
Billy is offline   Reply With Quote
Old 04-07-2015, 01:21 AM   #8712
Suspended
1.6 inches and 1.7 centimeters
Mantis Toboggan is offline   Reply With Quote
Old 04-07-2015, 02:35 AM   #8713
egobrkr's Avatar
Trader Rating: 26 (100%+)
I have 6 race days and have changed the diff oils 1 time. All my diff do not leak. I run 7k 100k 4k
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-07-2015, 02:56 AM   #8714
HSV427's Avatar
Trader Rating: 22 (96%+)
Out of curiosity how does the car handle with those diff oils, I'm still running the stock setup cause our track is very loose but i was thinking of dropping them down from 10/100/10 to 7/100/5 but I'm not sure how it will effect the handling.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 04-07-2015, 04:39 AM   #8715
jhautz's Avatar
Trader Rating: 85 (100%+)
Metric. 1.6mm. 1.7mm.
jhautz is offline   Reply With Quote
