Like Tree28Likes
Old 03-30-2015, 03:52 PM   #8656
SeanKewley's Avatar
I apologize for taking the thread off topic with my inquiry about tires and this kit on indoor clay tracks. I'm new to the forum and didn't understand this was bad etiquette.
SeanKewley is offline   Reply With Quote
Old 03-30-2015, 04:13 PM   #8657
Ok so I'm going to go tell all my family I love them and I'll see them on the other side. All of this apologizing, is the world ending and no one cared to let us all know?
CaseyD is offline   Reply With Quote
Old 03-30-2015, 04:28 PM   #8658
Sorry about that.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 03-30-2015, 04:32 PM   #8659
SeanKewley's Avatar
Me too :-)
Old 03-30-2015, 04:34 PM   #8660
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
check these out. way cheaper than HB
http://www.avidrc.com/product/5/acce...cessories.html
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-30-2015, 05:09 PM   #8661
Two questions, first is there a measurable difference in arm stiffness between glued plastic and screwed in carbon? Not sure if I could bring myself to glue carbon inserts in.
Second, has anyone found any other brand camber link ends that are captured like the two outside rears? I know it's driver error but I've been through 3 of them in a fairly short time. I'm just wondering that way if I get in a pinch I could throw them on. Plus if you look at the stock ones they are pretty flimsy from the get go. I've looked at traxxas captured ends but they are too thick. Thanks.
Old 03-30-2015, 05:17 PM   #8662
I believe serpent srx 2wd mm uses captured camber link ends.
turtle189 is offline   Reply With Quote
Old 03-30-2015, 05:21 PM   #8663
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
A little work but you won't break another oitside rear link end. Scuff up the little divot on each side where it breaks and clean with alcohol. Take CF plate and scrape the edge with a razor blade to make CF powder. Put some powder in the divot and add a drop of CA. Let it dry (no accelerator) and file any lumps that may interfere with the hub. Through testing ...I'm 100% confident it works
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-30-2015, 05:21 PM   #8664
yeah, the carbon inserts stiffen it up a lot. you would need to try it unglued to see if you like it. I dont know your traction levels. but gluing the inserts in does add more stiffness.
Old 03-30-2015, 05:57 PM   #8665
I run the fronts glued plastic right now. Not sure if i really notice a difference, believe me though, definitely my lack of skill not that glueing them in didn't make them stiffer.
Old 03-30-2015, 06:00 PM   #8666
serpent? I'm trying to find a more readily available part, not harder to find. just playin, thanks.
Im going to try the carbon powder trick.
Old 03-30-2015, 09:38 PM   #8667
Originally Posted by bhambrent View Post
Damn now I want new tires and ice cream.
Me too!
Just peeled a glued carbon insert... had to cut away some plastic from the arm to get it started. Once it was out, I used a razor blade to scrape all the glue off... it's now ready to glue into another arm! Moral of the story... don't feel bad about gluing the carbon inserts, they are still reusable.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 03-30-2015, 10:06 PM   #8668
nitro2be's Avatar
Originally Posted by Sofa King View Post
Me too!
That is good to know I was wanting to glue mine.so does this mean you broke a Front arm?
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 03-31-2015, 06:39 AM   #8669
Well, yes (sort of) finally after nearly a year... Our recent track has a chicane with a sharp pipe that can catch cars if too close. I caught it with the rear tire and it just pulled the hub off of the arm, the plastic of the arm flexed enough for the hinge pin to come out. I put it back together and ran for several weeks, then it happened again (same place) and I put back together and ran a few more weeks. Finally the third time it happened, it started to tear some of the plastic away... I could have continued to run it, but decided to replace it (and I was curious to see if the CF plate could be recovered). I also have a set of outer hinge pins from another car that uses e-clips that I thought about using, as they would not allow the arm to spread... perhaps a nutted outer hinge pin would be good.
Sofa King Racing
Old 03-31-2015, 07:05 AM   #8670
Cheaper still all 4pcs and include screws.
http://www.ebay.com/itm/HB-D413-Grap.../161642733826?
I've ordered 2 sets of these and they are good quality and perfect fit.
GimpyGolden is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
